I broke out the old quarter wave vertical for this activation. Its main vertical wire was faulty due to having lost some length. It was repaired before going up to the hill. It was 1:1 swr across the band.
I think it worked well but I was running 50w output for the last half of this activation, 25w in the first half.
Biggest signal heard from almost anyone, was Herbert OE9HRV whose signal actually sat at s9 on the blobometer on the FT857. I have sent him a short video of his CQ call, via VK1AD.
I was very pleased to make 18 S2S contacts, one of which was with G/NP028 which is the summit I activated in 2016. So itâs a new complete. Others worked included Ignacio EA2BD and Jorge EA2LU both of whom I met and activated with when in Spain in 2019.
I recently recalibrated my FT857 on HF by making 100% power = 50w. For 25w you set it to 50 on the menu 075 setting. A previous owner of the âall pots to the rightâ brigade had completely messed up the power settings on the three groups of HF bands. He left the HF1 TX Gain far higher than it should have been too. When starting todayâs activation I forgot about the half power settings and that caused me to start the activation with 25w instead of 50 intended. This is due to finding that running 100w for even a short time overheats the BMS in a 7AH battery so as this radio is just for portable operation, all power settings are half of what is indicated.
Thanks for all the contacts, it was great fun. Packed up just as the sun set.
