Can hear chasers chasing Andrew on G/NP-028 as normal no hearing the activator due to fact he’s only 420Km from here northwards of my location. and sitting here hoping he go to 40m WHEN;-
All of sudden his signal climbed to 5/9 came out of the blue
Made good contact and said hi to mike too YYY
Signal dropped off and gone
OH wow
The impossible just happened
Love it when propagation laws are broken as we understand them
have been hearing a few Mid uk stations working Sota’s on 20m today but not like that
Same situation here in YO last weekend: worked YO9RIJ/P on 20m in SOTA with 5/9, under 500km between us. Hearing other YO stations booming. See the video about this sporadic-E session: https://www.youtube.com/watch?v=wa-TxDkVv4Y
We often hear of Sporadic E on 10m & 6m, but of late it has also been present (from what I have heard) as low in frequency as 20m.
I think the periods of Sporadic E that can be used on 20m are shorter than what we are used to on 10m.
The more we go into a sunspot minimum, the more important predicting Sporadic E will become. In this case it brings shorter distance communications on 20m, which - in this DX-prone hobby - would seem to be negaitive but if nothing is happening on 40m, it’ll be good to have the contacts on 20m via sporadic E instead.
For me, from where I am situated in Central Europe more short range 20m contacts would be very welcome as normally anything under about 500 miles from here, I simply cannot hear on 20m - and that’s some very SOTA summit intensive areas!
I’d have thought that, while Es is most often noticed because of its effect at the shorter wavelengths (because they get F-layer propagation rather less often), it’s likely to have an effect over most of the HF bands, but because the lower ones are also more likely to get propagation via the F layer it’s less obvious when Es is playing a part unless the skip’s exceptionally short. If I’m remembering correctly, one of the things that came out of the RSGB 5MHz experiment was that Es was a significant contributor to propagation on that band.
