Problems with Eremit battery - Solved
I am still enthusiastic about the Eremit LiFePO4 batteries. I have a 12V 2 Ah and two with 4 Ah. I also like to use the two larger ones in parallel when I draw larger currents… e.g. for the PA.
I use the smaller one for my small CW TRX (e.g. Mini QCX,…) but it is actually always in my bag to supply the KX2, whose own battery is now 6 years old and not quite as powerful.
Recently I noticed that the buffering of the KX2 battery was not working properly. Somehow there were interruptions.
After some investigations I found that the cause of the problem was the Eremit battery: the cables there have silicone insulation. This is good and brings flexibility. The wire inside is not so flexible, however. And so a cable broke inside the insulation at the edge of the battery, which led to temporary interruptions. The test is quick. You simply twist the cable with your fingertips and see how the insulation twists and then tears.
Unfortunately I didn’t have any more flexible wires at home. So I shortened the old wires.
The battery has 2 blue covers. If you cut open the top one, you can put it back on upside down. To get better access to the soldering points, I cut off the contact tab of the middle battery and soldered it back on later.
Yesterday I told Stephan @HB9EAJ, who I was with on HB/BE-153, the story and he told me that he had had the same experience.
Perhaps one of you will have similar problems with the battery and now have an idea what the cause might be.
Yes, I have the same problem with an Eremit 2Ah LifePO4 battery from 2021 that I have used hundreds of times.
I haven’t fixed it yet because I have other Eremit batteries that work fine, but this model seems to be sensitive to this kind of failure.
I’ll let Eremit know about this problem and link to this post so that they know about this particular problem.
So if other users of this or a similar Eremit product have had a problem, please leave a comment below.
73 Stephan
I have the same 2Ah battery, since the length of the wires allowed for it I bent them 90 degrees across the side of the battery for stress relief, if they’re going to break they’ll be easier to fix.
The Eremit 4 Ah is a great little battery. It’s noticably lighter than the 4S1P Zippy 4.2 Ah LifePO4 it replaced. When I got it I was a little surprised at the light gauge of wire used on the output compared to the Zippy. Also, the leads appear to be terminated right at the top corner with virtually no shrink wrap to offer strain relief. Perfectly fine if the battery is mounted inside equipment, but not racking up low-cycle fatigue damage on mountain tops.
I’ve taped the leads to the side of the battery, which at least means that any issues will be easy to deal with.
73 John
Snap! I did exactly the same with my 4Ah Eremit.
Fixing the cable on the side seems to be a popular solution.
Me too, but mine are side strapped with tape.
Thank you all for your input, it was really helpful!
As promised, I have contacted Daniel Beck, the owner of Eremit, and sent him a link to this post. He is an open and helpful person who has answered my battery related questions in the past. As you will see, he also likes to improve his products!
Please see the excerpts of his answers which I have translated from German to English using Deepl:
I have read through the discussion and am surprised that the problem seems to be a bit bigger than previously thought.
I myself have one request per about 600 batteries regarding broken cables, so I have not yet recognised the whole thing as a general problem.
You are right, these are not the fine strand cables we normally use for our projects - but I think there are several problems at play here.
The 12V 2Ah has the output of the connection cables directly behind the soldering points of the BMS. The cables are therefore bent just behind the soldering point, which inevitably leads to breakage after intensive use.
To be honest, I still haven’t found a solution to this problem; a heat shrink tube had the opposite effect when I tried it. And re-routing the cables around one side of the battery would just increase its size. For the next series (December 2024) I will try extremely fine 18AWG cables at the output, but I don’t think this will solve the problem in the long run.
With the 12V 4Ah, we’ll put shrink tubing over the output in the future and use a fine 16AWG here, I think we’ll have the problem under control.
Pure copper strands are tricky. They are susceptible to oxidation, and the fibres in the silicone cables have a lot of surface area and not much volume, so I’m not sure they won’t oxidise completely after a few years.
The main problem seems to be the kink point and the number of fibres. I will definitely fit the new 2Ah with better 18AWG with finer fibres, as well as replacing the wire of the 4Ah and covering it with heat shrink tubing. If there are any other ideas, they are welcome.
73 Stephan
I have just bought two EREMIT 2Ah LiFePO4 batteries. What is the best fast and secure way to charge them ??
VY 73,
Nico
They have a BMS installed so you only have to apply a fixed voltage to the terminals. The Eremit web site says 14 to 30V. I use my Imax B6 charger in LeadAcid battery mode (it applies a fixed voltage that is current limited.)
My B6 has LiFePO4 Charge as distinct from Balance Charge. I assume yours does too. Is that not more appropriate or am I missing something here? Currently it doesn’t apply to my situation as I have the Zippy type of batteries and use Balanced Charge with them. However I am looking at other options for the longer term.
I charge it with a 4S 1A LiFePO charger from Eremit (when I’m away) or if I fancy with my B6 mini charger.
73 Stephan
Built in BMS to handle over-voltage, under-voltage, over-current, balancing. You apply a fixed voltage >= 14V and let the BMS do its business.
In PB mode, the B6 provides essentially a fixed voltage. I use it and not a fixed 14V PSU because the correct plugs are fitted to my B6 to connect to the Eremit battery.
My version 1 of the B6 does everything correctly. My very new B6, version 2, says “balance connect error” when I connect either of my non-balance LiFePo to the charger set at LiFePo charge (not balance charge). Should I send it back?
Elliott, K6EL
Don’t know Elliott. I’ve only ever used mine to charge LiFePo or LiPo packs in balanced charge mode with the main and balance connectors connected.
Just tried this and I get the same result when the charger is connected to a Zippy type LIFEPO4. The B6 won’t work in “charge”, " fast charge" or even “storage” modes without the balance oonnection. It will however “discharge”.
Using Pb instead of LiFe does work, even with a Zippy type battery.
Hi Elliot,
I had the same problem with my B6 mini and it took me also a moment to find the culprit. My error message was “MISSING BALANCER CONNECTION”.
The solution to disable the balancer port is actually simple and self explanatory:
On the B6 mini go to the menu BATT/PROGRAM > SYSTEM SETTING > Bal. Connection OFF
Unfortunately, the PC software ‘Charger Master’ lacks this setting. I told IMAX about and they responded that they will add it to the next version, but the updated version 1.30 that I used recently is still missing this setting.
But in the meantime, a newer version 1.39 is available (scroll down).
UPDATE: This new version still lacks this setting.
Also make sure you have installed the latest firmware.
73 Stephan
That worked. Thanks, Stephan
Regards, Elliott
