Problems uploading an ADIF from an activation
Hi,
I just tried to upload the log from my most recent activation but upon clicking the submit button nothing happens. I found some error messages in my browser’s developer console:
Object { ownCallsign: "DA2PK", date: "8/4/2026", dateObj: Date Thu Apr 09 2026 18:34:32 GMT+0200 (Central European Summer Time), summit: "DM/HE-570", qsos: (41) […] }
main.dbdc638a7ab44d1a.js:15:242140
ERROR TypeError: can't access property "latitude", o is null
    Oc https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:15
    next https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    _next https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    et https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    vo https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    C https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    s https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    u https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    invokeTask https://www.sotadata.org.uk/en/polyfills.878e19c4d9e9824f.js:1
    onInvokeTask https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    runTask https://www.sotadata.org.uk/en/polyfills.878e19c4d9e9824f.js:1
    Z https://www.sotadata.org.uk/en/polyfills.878e19c4d9e9824f.js:1
    N https://www.sotadata.org.uk/en/polyfills.878e19c4d9e9824f.js:1
    F https://www.sotadata.org.uk/en/polyfills.878e19c4d9e9824f.js:1
    t https://www.sotadata.org.uk/en/polyfills.878e19c4d9e9824f.js:1
    scheduleTask https://www.sotadata.org.uk/en/polyfills.878e19c4d9e9824f.js:1
    onScheduleTask https://www.sotadata.org.uk/en/polyfills.878e19c4d9e9824f.js:1
    scheduleEventTask https://www.sotadata.org.uk/en/polyfills.878e19c4d9e9824f.js:1
    u https://www.sotadata.org.uk/en/polyfills.878e19c4d9e9824f.js:1
    594/handle/l$</< https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    _trySubscribe https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    j https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    Re https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    subscribe https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    xo https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    bt https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    nt https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    Ug https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    b https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    pr https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    gi https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    loadPOTAReference https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:15
    submitLog https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:15
    pTt https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:15
    G4 https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    decoratePreventDefault https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    addEventListener https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    listen https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    V4 https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    W https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    Y5 https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    XM https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    Hde https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    createEmbeddedViewImpl https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    createEmbeddedView https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    _updateView https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    set ngIf https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    n4 https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    WM https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    Ua https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    S https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:3
    bTt https://www.sotadata.org.uk/en/main.dbdc638a7ab44d1a.js:15
main.dbdc638a7ab44d1a.js:3:72422
Is this an issue on my side? The ADIF I’m trying to upload was generated with PoLo, just as the ADIFs from all my other previous activations.
Thanks
Philipp DA2PK
If you just post about your problem here you are relying on someone from the MT reading the message and acting on it. Instead, it’s better to use the Contact SOTA form to ensure the message gets to someone who will help.
We have had many issues with the contact form, so make sure you get a Captcha on the form (clear your cache for SOTA if one is not there). A bug with correctly entered Captchas failing was fixed a few days back.
As I’m here, send the ADIF to me andy.gm4lld AT gmail.com
Thank you. I sent you the ADIF and will keep that in mind for any future problems.
This is fixed now. It was caused by having multiple POTA refs in your location field. The fix is twofold: one, handle errors from the POTA API more gracefully, and two, if multiple locations are submitted, only check the location of the first one for SOTA purposes.
