Problem with Android tablet
Have been using a Lenovo tablet for a couple of years with Sotawatch3 no problems.
Easy to see the font on the screen and use.
Don’t know what happened, maybe I touched something but the font has become hopelessly small and very hard to read.
Thought Sotawatch automatically changed the font so as to accomodate a smaller tablet screen.
Do I have to reload Sotawatch or do something else ?
Thanks for any advice, Wal VK2WP
Hi Wal,
Your tablet also determines the display characteristics. There have been changes to SOTAWatch which may have contributed but I think all you need do is go into your Setup menu and adjust the font size.
I’ve not had to adjust anything on my Android phone since the change.
Good luck.
Ron
VK3AFW
Hi Wal,
If you have a keyboard attached to the tablet (possibly wirelessly) try pressing and holding down the Control(Ctrl) key and press the plus (+) key a couple of times to make the font larger (and if you go too far, control and minus, to shrink the font).
If you have no keyboard attached, then the two finger press on the screen and stretch should work but only for the current session.
You can also try the three vertical dots in the top RH corner and select “go to desktop site” to see if that is any better for you.
Problem solved, at my last activation was sitting on a cheap closed cell foam sleeping mat. Hot dry day and this mat generates static electricity like fury. The stylus I was using must have acted as a sparking rod.
No wonder the tablet became unusable every time it was touched. Sweaty fingers did not help.
Font size and all operation now restored to normal operation. Should I ever use this mat in dry weather will take a water sprayer so as to dampen it down and kill the static.
Thanks for the commentS, 73’s Wal VK2WP
