Problem to upload csv activator log for S5/CP-015 summit
Very strange problem:
I am getting [object Object] error message while trying to upload csv activation file for S5/CP-014 and S5/CP-015 summits. After many trials, detailed checking of file sintax etc, I discovered that there is no problem if CP-015 is replaced with another reference, e.g. CP-014, CP-016 . in the log file. So, there are no errors in the log file, everything is OK, just S5/CP-015 is not accepted by database SW (?!).
Any help?
73, Mirko S52CU
p.s. Log file is for S56LXN activation of S5/CP-014 and S5/CP-015 on 07/10/2024
Mirko, send me the csv file please.
andy.mm0fmf AT gmail.com (fix the AT!)
Thanks Andy,
Mail is on the way.
73, Mirko
Received and being looked at.
Try now, Mirko. There was an issue with the first activation of the summit in 2008 with a garbage time of day for the first QSO. I’ve fixed that so it should be fine now.
Thanks Andrew,
Will try when back at home and will let you know.
73, Mirko
Success !!!
Thank you very much for your help.
73, Mirko S52CU
