powerful solar flare
Dear Hams
Today Andreas, HB9HCI and myself we were on HB/OW-001 ( Height: 3238 m / 10623 ft). There were vy poor prop. At home I googled an found this info from Frank, W3LPL!
73 de HB9BIN, Jürg
The most powerful solar flare and CME thus far during solar cycle 25
From W3LPL, Frank Donovan
__________________________________________________________
A solar flare from massive solar region 2786 at 1311Z on Sunday 29 November was the most powerful solar flare and coronal mass ejection (CME) thus far during solar cycle 25. The sun’s activity is now rapidly increasing after a slow increase in activity this year following solar minimum last December
The flare and CME erupted from just behind the southeast solar limb and was not Earth directed. The shock enhancement/glancing blow from the CME may cause unsettled
to active geomagnetic conditions on 1-2 December. There is a
chance for additional M-class solar flares through 2 December and a slight chance for much stronger X-class flares.
The WSA-Enlil model shows the 29 November solar flare and associated coronal mass ejection (CME). Earth is the yellow dot.
spaceweather.com describes this effect as follows:
X-rays and UV radiation from the flare ionized the top of Earth’s atmosphere, producing a shortwave radio blackout over the South Atlantic: map. Ham radio operators and mariners may have noticed strange propagation effects at frequencies below 20 MHz, with some transmissions below 10 MHz completely extinquished.
Everyday’s info abt sun activity you can follow here: The Sun Erupts Again, Killer Electrons, Super Lightning | S0 News Dec.1.2020 - YouTube
That radio blackout yesterday was an M-5 flare, according to the SpaceWeatherLive app.
Elliott, K6EL
Unfortunately the impact of a strong CME (G3) is also predicted for Monday morning March 25th … so no reason to doubt your own equipment this time either, hi.
Today for the first time in the last 2…or 3 years i miss an activation on Monte Lupone I/LZ-323 … i was using my QMX and 20 Meter HwEf and in half and hour … only two qso on 20 meter cw band (thanks @EA2DT and @dl6wt)… only qrm in all band and no other cw station…
But after i discover this:
https://twitter.com/_SpaceWeather_/status/1771930033692537025/photo/1
Strong G3 geomagnetic storm (Kp7)
Threshold Reached: 15:46 UTC
GJco-dvWEAAPEFi
73 And IW0HK
very impressive …
(c) Radio Communications Dashboard | NOAA / NWS Space Weather Prediction Center
yes… i’ts the first time for me that i have the felling of "switch off " of shortwave band…
73 And HK
Current situation:
ScreenHunter 493
