No topic for this app yet? What are you using?
After years of struggling I installed peakfinder app today. Working fine. Would be nice, if there were sota references displayed. But within my local surroundings, I know the qualifying summits.
I will report my experience after my next expedition. https://www.peakfinder.org/en/mobile/
Peakfinder is cheap so I’m not complaining but I find it has limitations.
The vertical marker lines don’t align perfectly with the actual scene on which they are superimposed. So, with a crowded summit horizon (like here in G/LD) I can’t always be sure which hill/mountain a marker line is pointing to. That’s not helped by the fact you cannot tell [without looking at a map] how near or far each summit is [because the bottom end of the lines is all the same]
I have been using Peakfinder for a while. You can adjust the distance that it “sees” so that your view isn’t so crowded and it is easier to pick out summits. You can also move the names/markers with your finger to align them.
I’m continuing to have problems with SOTA Goat app on iOS. It would be nice to have a near bug-free app when I need it. It’s come to the point where I’m sending out test alerts before leaving the truck to make sure it’s working.
I’ve been using Peakfinder for quite a while now. I like the fact that you can take a picture and add an overlay later.
When it comes to SOTA Goat, I gave up on it some time ago (temporarily I hope). I use sotl.as to spot; it works quite well even with poor LTE/3G coverage, and I appreciate the functionality to list the nearby peaks.
