Outd Log by HB9GVC
Pierre
Thanks I will have to give VK port-a-log a go. One feature I love is being able to read spots within the app, so you don’t have to leave the app. Outdlog also lets me know, if I have already worked someone, which is useful (I am a S2S Junkie) LOL
Cheers
Martin
VK Port-a-log does the same. Swipe left to bring up the latest spots. Click one and it will populate the details from the spot.
Work the S2S, update RST and save.
I think there is also a colour code if you worked the station already :thinking:
Ha ha I have looked at it a couple of times but never discovered that! THANK YOU!
No answer so far :frowning:
In the past it taken a few hours max to get an answer from Thomas.
May be colleagues from Switzerland may have any tips …
73, Jarek
Spots issue is solved :wink:
73, Jarek
Hi Jarek
I checked with my installed Outdlog app. Spots are not working with me.
73 de Pierre F5MOG
Bonjour Pierre and Jarek,
Spot working but very slowly and not all spot are showing.
73, Éric
F5JKK
Edit : On iOS
I will e-mail link to this thread to Thomas for his double checking.
73, Jarek
Strange things have happened today. The Spots have started working (this is for the first time in over a month). However they are slow. Here are three screen grabs all taken at the same time. You can see Outd Log is not showing everything that the others are. This is on Android. With multiple refreshes on the Outd Log screen.
Martin
I restarted my phone (IOS) and reauthenticated login.
After that last sport is from 9:25 UTC, now is 9:48 UTC and on sotawatch are 19 newer spots more.
73, Jarek
I tested now several times. For me it seems that it is working again.
Thanks to @SP9MA Jarek and others for bringing this issue up and solved it. Much appreciated.
73 de Klaus
I just tested. SLOW and really not in real time on my phone…last spot 18min ago, while on sota spotter, I have 8 more spots…
Vkportalog and sotaspotter are giving me same info.
73 de Pierre f5mog
Hi Roger,
I noticed that too.
But since today the function works again!
Joerg
DG0JMB
Thanks for the info Joerg @DG0JMB :+1: Works.
73 Marcel DM3FAM
So can someone throw some light on this? Obviously the app hasn’t been updated, so what has changed to make it work again…? What ever or who ever THANK YOU!
Martin
For me Outd Log has stopped updating again! It is such a good app but can not be relied on.
Maybe time to give VK port-a-Log a go
73 Martin
Yes. Same here. I recognized it today on the summit.
I really like the app. So, hopefully it gets repaired soon
Yep seen the same and have moved over to vk-porta log, I can see no benefits to outdlog over portalog now I’ve updated the names.csv file. It alerts you to the spots and makes s2s contacts a breeze. Just wish there was a POTA side to log using it as well and I would be very happy.
Cheers
Rich
2W0LWF
Same here, Spots didn’t work yesterday.
Is someone in touch with Thomas, HB9GVC?
73, Roman
Apart from this problem. Has anyone of you tried an external keyboard ???. Can you tell me, if with the Return/Enter key on the external keyboard, you jump from field to field.
I can’t get it!!
73 de Dani EA5M
