18168KHZ IS OUR LIMIT
EA5ER/P 18.170 SSB [EA5/VL-076]
HEARING HIM WORKING A FEW UK STATIONS ![]()
2E0FEH
2E0FEH
Moved to 18168 problem is still out of band as its USB highest you can go is 18165.3khz on USB mode be ok on LSB LOL
2E0FEH
You mean 18168kHz!
Is that even in band in Spain?
Karl I didn’t realize till after then quickly deleted entry… Thanks for this though as I wasn’t sure.
Best 73
Yep fat fingers again
And yes 18168 is limit on 17m band in all three ITU regions.
Never could remember all limits, hence keep a handy guide at hand to remind oneself at times.
CORRECTED THE NUMBERS NOW TA
2E0FEH
No. This failure to understand dial frequency and bandwidth is happening far too often. It’s a failure to understand the basics of operating.
VERY VERY IMPORTANT ON 60M AS SHARED BAND WITH THE MILITRAY
Its is a basic understanding of band as if in FM mode would have to move the TX to 18163 as 5khz carrier either side of the Transmission. If FM was used on 17m of course as a example.
Does state in the band plans the bandwidth of transmission must be taken into account…
2E0FEH
