Jirka on OK/JM-064
Eric,
I missed Jirka’s on this summit because I was at work
Phil
I downloaded the last version because I didn’t work FT4. Next Jirka’s summit I try it.
Give it a go now Roger - FT4 is FT8 on steroids. Two QSOs a minute this time of day around 14080 KHz!
73 Phil
Jirka timing is out on his computer - fast by one second Roger, so more QRO needed to make QSO!
73 Phil
Yes , he should synchro time but not sure he uses GSM or GPS Dongle…
THANK YOU JIRKA AND HOPE YOU CAN FIX THE TIMING…
NOTE THE SUPPLEMENTARY DX QSO ON 80m IN BROAD DAYLIGHT AT MY END!
WHAT AN AMAZING MODE FT8 IS FOR CUTTING THROUGH…
Phil @G4OBK Jirka moving a lot 2220Hz
