November 2025 Trans-Atlantic S2S reports
Not the best band conditions this year here in Arizona, but made 79 QSO’s from my summit (W7A/YV-077).
Nine EU contacts, 3 EU s2s contacts, and close on a few others on 10, 15, and 20 meters…all on CW.
Worked DL, F, EA, SB, and heard other EU countries I could not pull out of the noise/QRM…
Twenty s2s QSO’s total (mostly USA+VE…DUH!).
So not the best conditions for sure, but not bad for the low flux numbers.
Anyhow, thanks to everyone for getting on the air. Fun as usual…!!!
Pete
WA7JTM….on W7A/YV-077
WOW!! great fall colors!!!
Pete
WA7JTM
Hello everyone,
I could not make it on Saturday but it was 6 degrees and windy in Western Québec on Sunday. The Sweepstake contest was running and making it impossible to reach QRP stations in CW. I moved to the WARC bands and made 9 QSOs including 4 S2S before getting cold. Nice day and looking forward to the next edition (with more warm clothes!)
George, VE2VAB
Three weeks after my total hip replacement surgery, I was still under driving restrictions from my surgeon. Fortunately, my friend Dan (KC7MSU) offered to drive us to an easy “drive-up” summit—Mingus Mountain (W7A/AW-010).
We arrived and set up on 10 meters. Dan called CQ around 7:30 a.m. local time and operated 10-meter SSB for about 30 minutes before turning the station over to me and setting up his own gear. I remained on 10 meters for the entire activation.
Although I missed several DX stations due to the pesky QSB, I was very happy with the overall results.
Results:
  • 56 contacts on 10 meters
  • 3 DX S2S contacts
  • 10 U.S. S2S contacts
DX stations worked:
F4WBN, S57S, EA3GNU/P, F6HKA, M0BKV, F5JKK, EA2GM/P, EA2BD/P, F5PYI, EA4WT, EA7ANC
Big thanks to Gerald @G4OIG for coordinating the TAS2S Event every year. It’s one of my favorites and I had a blast again this year!
Charlie NJ7V
On Saturday, we did a successful activation on Patschaberg OE/ST-363
All in all great weather for this event besides a little cold with a few windgusts and when packing and descending in the dark after beeing on the summit for over 5h.
76 QSO in the log from 4 operators with the Callsign OE6XUG/p which we had the pleasure to “borrow“ from the Club station of the RCCW at the Technical University of Graz was the recap of the day.
We also made quite a PR on the mountain as a bunch of exchange students from a different Uni who happend to hike the summit had fun helping us with throwing lines in the tree and a fellow student quite literally said we might see him soon on on air too because he was impressed when he saw what we did there.
Luckily we did actually not need the QRP backup rig we had brought even though we forgot the powercable adaptor for the big trx, but were able to do a questionable make-shift-repair that held surprsingly well.
So in the end with a 100W Yaesu Radio and 3 antennas (10m T2LT,40-10m EFHW,20m Dipole) to choose from, everybody had at least one transatlantic QSO in the log.
Thanks to everybody who participated and especially to Scott @K2CPT who was my first ever transatlantic S2S QSO.
OE5LAE
OE6CBX
OE6MJR
OE6NOA
On Saturday I went to my lowly summit W2/GC-122, Shaupeneak Ridge. The summit elevation is only 270M (886 ft) ASL lying above the Hudson River opposite the FDR Presidential Library at Hyde Park, NY. The weather was mostly sunny with high temps 10°C (50°F) and slight breeze. The summit is easily reached from an upper trailhead leaving only a 450M (1500’) walk from the parking area. My rig was FT-818 at 5 watts into an 40M EFHW Inverted-7 with the apex at 32 feet, tail at 20 feet AG and feedpoint 6 feet AG with tail aligned to face Europe.
The morning started at 1300Z with good openings on 10M and later 15M. I did not try 12M because of only a few spots and the effort required to add a link to the deployed Inverted-7 in tree branches. This is my third time using the inverted-7 for TA S2S, it seems to work well.
Total 50 QRP CW contacts, including 14 trans-Atlantic s2s contacts, 12 stateside s2s contacts and 14 EU chasers. Many thanks to the operators with good ears on the other side of the Atlantic for hearing my QRP signal, including: IK2LEY/p, EC7ZT/p, HB9CDH/p, EA3GNU/p, G4TGJ/p, HB9EKO/p, IW2OBX/p (many attempts !!), MW0IDX/p, S53XX/p, G8CXK/p, EA2BD/p and EA2GM/p (sharing the tent). Best DX was likely S53XX/p.
Thanks as always to the NortheastSOTA crew VA2EO, N1ZF and K2CPT for their local NA s2s contacts.
Stay well & 73!
Mike, WB2FUV
Now THAT is an activation worth doing. Stunning views! :ok_hand:
You were my only TA S2S contact of the day. AB8CI and I went out early in order to catch you folks in EU/UK and hardly heard anyone over there. :frowning:
I had another of your countrymen chase me over and over, but either his accent was very thick or he had a radio issue because despite a strongish signal, I struggled to get his callsign. Eventually I did, but it was an effort.
Chris
2025 Trans-Atlantic S2S party
Despite the unfavorable weather, I decide to head out anyway, heading for Monte Purito, above Selvino, easily reached in a 20-minute climb.
This decision was also due to the heavy backpack, two antennas and accessories, three batteries, and warm clothing.
During the car ride, I hit showers at least three times, the last one 10 minutes from Selvino, but the weather radar comforts me.
Once in the activation area, I decide to set up only the 16-meter LW for now. The morning will see me shrouded in low clouds several times, as I carry out what is a “normal” SOTA activation, with calls and hunting for S2S.
Since it’s not raining, I decide to set up the vertical, 5 meters telescopic whip, but mounted just over a meter off the ground, with four radials of about 350 cm, also raised off the ground.
Some signals are starting to arrive from the USA. On 12 meters, I hear an activator arriving with a clear signal. I wait for him to clear the pileup of European hunters, then I throw out a couple of “S2S” calls… He hears me, and I complete my first transatlantic S2S QSO.
I decide to stay with 12 of me and call, and I log a few US hunters. Then I hear a strange callsign and have him repeat it several times: D4BHU, Cape Verde, who even greets me by name. I realize it must be Fredi, HB9BHU, who often travels around the world… A new country for my personal DXCC QRP.
I make a few CQs on 10, and a few US QSOs come in there too.
Meanwhile, I don’t neglect the “normal” S2S calls with European activators.
For about three minutes, a light rain shower throws me into a panic: I cover my radio and batteries with my raincoat, ready for a quick evacuation, but luckily everything clears up.
Around 4 PM, I’m a little tired, so I decide to call it a day with 100 QSOs, including 53 S2S (5 USA, 1 VE). Not bad with 5 W!
In short, I did well to go; it was a great way to celebrate my 800th SOTA activation!
Thanks to all, chasers and activators!
73 Fabio
Pleased to work you S2S and well done on perfect CW operating. Super photos. After I had run through 15, 12 and 10 m, I almost moved on to 40 m and then QRT but decided to do another short spell on 15 m first, during which you were my last DX S2S.
Operating for about 2 hours from Brushy Mtn, W4V/LX-018 on Saturday, I managed eight S2S with Europe: five on 15 m CW and three on 10 m CW. This was quite a bit fewer than at last year’s November S2S event, but still a success and not bad considering the fair propagation and poor weather in much of Europe.
Thanks to @EA3GNU, @G4TGJ, @IW2OBX, @G8CPZ, @IK2LEY, @HB9EKO, @G8CXK and F4LEK for being there despite the elements.
Also thanks to @K4RXL for a S2S on 2 m FM and a rare complete of W4V/LX-021 which has only seen our two activations.
HF equipment: Xiegu X5105 at 5 W, linked dipole hung from tree limb in inverted-V, broadside to EU.
Typical for Oct. and Nov. in W4V, the weather was dry, not too cold, light breeze, and nice fall colors. Unfortunately, watching spots drained my phone’s aging battery before I could get photos from the summit.
However, I did get a shot on the hike up, 1.5 mi = 2.4 km each way, 1100 ft = 335 m gain, partly on a good trail, part bushwhack.
Matt
Hi
As promised, our report, activation of Mt. Erreniega, EA2/NV-092
This year weather wasn’t very good, with rain forecasted. My friend Javier, EA2GM, planned a visit in my town and we agreed to try a joint activation. We couldn’t start early, so we chose an easy drive up summit to save time.
Gear: KX3 @ 10 watt, EFHW for 21 & 28 MHz in vertical setup (bent).
We had a second set of gear and antennas but couldn’t be deployed due to the weather.
When we arrived it wasn’t raining yet, so we first installed the EFHW wire and connected the radio.
Right after switching on 28 CW (15.50 utc) we heard NJ7V calling CQ and we logged him first.
The first drops arrived and we quickly installed a tent with enough space for both, that allowed to stay dry and protected from gust, strong at times.
We chased a number of S2S first then tried CQing at times, running by turns. It was a great afternoon in the end and felt our tiny signal was hard to copy sometimes on S2S, but the operators were very patient and we repeated numerous times until completing the QSO: good operators!
Agree that conditions were not the same than last year, with remarkable QSB, but again we had lot of fun tuning up and down the band as spots keep updating.
Time on: 15:50 till 17:40 (1h 50’)
EA2BD qso: 13 from which 11 NA, 1 EA and 1 EA8.
6 NA S2S (NJ7V, WA7JTM, VA2EO, WB2FUV, N1ZF & K6ARK)
EA2GM qso: 13, all from NA.
8 NA S2S (NJ7V, WA7JTM, VA2EO, WB2FUV, AA3TZ, N0QLR, N1CLC & K6ARK). His map here:
To our surprise, starting late in the event, we found 10 meter with better signals from W6 & W7 activators first.
Our bodies were fatigued from lying under the tent while keying CW for long time.
It was fascinating to hear the NA activators while hearing around the noise of the rain hitting on the tent.
When it got dark we had to use a headlamp, and once the band seem to be closing we stopped and decided to call it a day. All in all, a great afternoon.
While dismantling and packing the tent it was a fashion to see the distant lights of the villages feeling alone in the dark and excited with the frenetic radio operation.
Thanks Javier EA2GM for joining and all for the S2S and chases.
Thanks Gerald G4OIG for organizing this event once again.
See you soon, 73 Ignacio.
Ps: I’ll try to edit a few videos I recorded and put here a link for YT .
Edit: video ready now: (featured @WB2FUV & @K6ARK , pity didn’t record some more…)
Hi Charlie,
I listened you on ten meters from I/LO-222, your signal was barely audible; I tried calling you several times, but without success. Better luck next time!
Ignacio and Javier, Congratulations on your activation; looks like a great day. Loved the video.
So cool to work Javi from a summit in Phoenix, Arizona
What radio and antenna were you guys running???
I setup a K6ARK random wire with a KX3 running 10watts.
Dear Ignacio and Javier,
Thanks for the TA S2S contacts, and including me in your excellent video. You said you were in a tent and it was raining — now I see what you meant. Hihi. Also Ignacio thanks for chasing today (Monday) for my W2/GC-028 first activation. Always a pleasure to hear you guys.
Stay well & 73! Mike, WB2FUV
So cool to get to see your operating conditions and station. I am impressed at how loud my signal was there. If the weather was good and more activators were out, I imagine I would have worked many more S2S. I appreciate your tenacity in making it happen despite the weather conditions. Also, next time I should bring the 7 element 10m Yagi out again :grin:.
I recorded some video as well, and I think I’ll have enough to edit and post up something soon.
Adam
K6ARK
On account of various family issues, my trip to Scotland to activate summits on both days of the event turned into a single day on the summit of Brown Willy G/DC-002 at the opposite end of the country. Given the poor weather conditions generally across Europe, perhaps this was a good thing as far as I was concerned.
It took me just over an hour to reach the summit from the car park to the north-west. A walk of around 3.4km with some 248m of ascent. I was quite pleased with my progress as I had not been out on a summit for some time and I was carrying 15kg with the extra batteries and the Slidewinder vertical, which in itself is quite heavy.
Ponies en route to Brown Willy, the summit in the background.
Just as I arrived at the summit, the first of the rain showers arrived. I sought shelter behind one of the granite outcrops and attempted to work out the best position to operate from. Unfortunately to get both some shelter and have a reasonable take off to the north-west left me with having to set up on the north-east side of the summit; not ideal, but workable across the sloping ground.
Brown Willy summit just before the first rain shower.
I was going to try 2m SSB first, but found that I had left a necessary link cable back at home. After having lunch while it rained, I set up the antenna and spread my large tarp across a gap between two rock outcrops to provide me with some shelter. I decided to try 40m SSB first and had a real struggle to make contacts. I later discovered the linear amplifier was not switching in and I was running just 2.5 watts. Anyway, I managed to qualify the summit on the band.
Moving to the event proper, I noted the main activity was on 10m CW. I was soon in contact with Roy WN3F. I moved off to call CQ, which netted me a contact with Eric VA2EO, a couple of US chasers and a couple of locals via ground wave. After a frequency move to work Matt W4GO and one more US chase back on my previous frequency, I bagged another S2S with Tom AA3TZ. I then spent a few minutes calling Dale N3HXZ, but he couldn’t hear me. Thankfully he then moved to 15m CW where we managed a contact.
Pole mounted vertical with my rough tarp shelter behind (between showers).
During my transmit periods, I noted that the issue with the switching line on the amplifier was persisting. This was very erratic and needed constant monitoring. Twisting the cable effected a temporary cure which would last for a short time.
As I was now on 15m, I decided to call CQ, but was called by just two EU chasers. Looking at the spots again, I saw Charlie NJ7V spotted on 10m, so I went back there, but try as I may, he couldn’t hear me. Just after 16:00z, I decided to move back to 15m and worked a nice run of contacts including S2S with Chris N1CLC and Mike WB2FUV, plus several US chasers. It was now starting to get dark and I was getting cold, so before packing up, I decided to concentrate on trying to work Pete WA7JTM, but he couldn’t get my call and in the end we had to give up. His signals were peaking s5 with me, but Pete sent that he had QRM at his end.
The take off to the north west over Rough Tor.
The view out to the east from near to my operating position.
… and the view south-east.
Overall I made just 25 QSOs despite making many more CQ calls this time.
7 Trans-Atlantic S2S – WN3F, VA2EO, W4GO, AA3TZ, N3HXZ, N1CLC, WB2FUV
8 Trans-Atlantic non-summit chases – KF9D, AC6ZQ, N4DH, K4QS, W2WC, VA3OPA, WB2PHL, AC7P
It rained on and off during my activation until around 16:00z and it was clear as I packed up. I descended in the moonlight and could see my way quite well, or so I thought. Approaching the car park I did manage to take a wrong turn on the grassy track which all looked much the same and I stepped into a drainage channel which was covered by vegetation. Two wet boots and two wet legs. Not my finest hour!
I am really pleased to read the reports in so far and to see that despite the weather, many activators really enjoyed the event. Reading that some made their first Trans-Atlantic S2S contact during the event was especially pleasing, as it was for that purpose that I suggested these events back in 2016. Many say I organise these events, but they really organise themselves and I do little more than set the dates in April and November and review the outcome to see whether any changes are needed. Long may it continue, even when I am no longer QRV. Many thanks to everyone that participated, both out on the summits and at home.
73, Gerald G4OIG (operated as G8CXK/P).
EDIT: A few people have asked me about my set up which on this occasion was my FT-817 set at 2.5W driving a MX-P50M amp to around 25 to 30W output to the Slidewinder coil based vertical with 5m counterpoises. To offset the non-optimum position on the hill, I ran three counterpoises vaguely WNW, NW and NNW with fourth set at SE. Did this affect my results to EU?… perhaps, though I did work S57S and S57AU with very strong signals on 15m. I still remain of the opinion that antenna positioning on the summit and orientation is really important.
@IW2OBX I copied part of your call sign (2OB). Thanks for clearing up the mystery and for the attempt. Catch you next time I hope. 73
If you don’t organize it, then thanks for inventing the Trans-Atlantic s2s Event. As I read your report I wondered “Gosh, I don’t recall an s2s with Gerald ???!!!”. So glad you signed the report with your aka G8CXK/p callsign. Hihi. It was great fun. Stay well & 73! Mike, WB2FUV
Saturday - Gun G/SP-013
20m CW/SSB - 13 QSOs, 7 S2S
Sunday - The Cloud G/SP-015
20m CW/SSB, 2m FM - 32 QSOs, 7 S2S
Zero DX. No TA QSOs. Certainly no TA S2S. Still good fun, never mind!
