I’ll be in Bergen and Alesund (Norway) starting May 16 for at least a couple of weeks with an option to extend the stay. I’m trying to construct a trip that is part SOTA (and even POTA) plus nab some long exposure seascape photos.
While I realize Norway is a huge place and has an abundance of peaks especially along the coast what areas beyond Bergen and Alesund are worth considering to find/access peaks that are trail accessible and appropriate for a solo hiker (I realize that in of itself is a “violation” of the Norwegian hiking code)?
Hi Paul,
I have spent 2 weeks in Southern Norway in 2022. I was further south, near Stavanger, Oslo and Skien, not touching the area where you will be going.
A general recommendation for hiking in Norway is the App Norway Topo Maps, available for I-phone and Android. This app was the only mapping source I have used for planning and hiking (except for SOTL.AS of course). You have to pay a one-time nominal fee to use it off-line. Well worth the few $$$.
I experienced a barren, but beautiful landscape void of trees and bushes. Bring some tent-pegs to tie your antenna mast to! I also found significant snow-covered areas in August starting at a height of about 1500 m asl. Avoid slopes facing North in higher altitudes and use high boots for hiking. I also recommend hiking poles.
I envy you for spending “a couple of weeks with an option to extend the stay” in Norway! Have fun!
Welcome to Norway and hope you have had a nice national holiday on May 17th. I recommend using the app ut.no if you can’t find gpx tracks in SOTLAS. When you have found the peak you want to go to in SOTLAS, search with the peak’s name in UT.no. It will give you good hiking descriptions to most of the peaks, as well as real time of your position when you use the app on the hike itself. It is unfortunately only in Norwegian, but by using DeepL or another good translation program you will be able to copy the text and translate it. Sorry I can’t give you specific recommendations, but this is because I live in another part of the country. Good luck with the activations
So great that you have received local help and I apologise that I could not contribute with local knowledge.
Keep enjoying Norway and I wish you many good activations and good radio conditions in the time to come
Glad to see you made it over to Norway Paul. I had the pleasure as a young Marine to be way up north near Alta back in the early 80s. On my bucket list to return some day too. Great seeing you down in Visalia last month too! Apologies for not making the SOTA gathering during the social hour gathering. Just too many friends I hadn’t seen in quite some time…Hopefully I’ll hear you on the bands…
