GM/NS-153 is a straightforward walk up the track to the phone masts, then a bit beyond.
Stac Pollaidh is a bit hard to find a place to put an antenna, I had two goes at this and needed HF to get enough QSO’s.
Best of luck with your activations.
I used an SPX100 base loaded whip on a mag mount base with counterpoise radials thrown over the rock. It worked surprisingly well on 20m for me.
I struggled a bit finding the return route down off the ridge both times, but it’s not really my area of expertise !
There’s a network of 2m ops. on Skye, the outer Hebrides and the west coast. I’d suggest contacting Gordon @GM4OAS for a kick off. He may have a few contacts.
Thanks @G5OLD@MM0EFI, I’m looking forward to (hopefully) working the Hebrides and will be sure to put out a CQ call the day before to check in with the local stations before the activation.
