Hi ! After 16 years of developing the first version of SpotMySota, I have rewritten all the app and it is now available the new SpotMySota 4.0.
It is a simple and robust app to send activation spot by SMS. Sotawatch config/password can be used and it has also the option to send with Andy’s MM0FMS format if your phone is registered there.
Optionally, you can enable GPS function in the config to see your altitude, the distance to the summit and a topo map.
So, a simple app without flourish to fill 4 fields and spot.
Thanks go to Mikel EA2CW for helping on the app design and his infinite patient on helping with the debuging.
Hi!
I just tested the SMS spot…:2 things
On the “Latest spots” page display EA SOTA Spotter
the time is not Utc (Time EA)
second: My spot is shown on the page, but not on the sotawatch (may be because of the “test ignore” comment?
Gerald
Guess there is a bug somewhere…!(now resolved)
I can send a SMS via OE Gateway, and also via EA gateway, that is OK.
But when i use the application, the Spot is shown on the EA gateway dashboard, but nothing on the sotawatch page.
… (resolved), Gerald
Dashboard shows EA time as expected. (Show header “EA Time”)
Your first SMS arrived BUT it seems your phone is not registered at MM0FMF SMS Gateway, so, it has not been pass to Sotawatch. (MM0FMF option ticked on config screen)
Your second message was sent directly by hand using sotawatch user/password format and it appears ok at sotawatch:
Your third message was sent again with SpotMySota but again ticket MM0FMF SMS Gateway on config, so it arrived to the gateway but no passed to Sotawatch.
So, just go to config screen on SpotMySota, untick MM0FMF Gateway registered and try to send again your spot.
Thanks for the tip (tick box must be blank) but as i can remember i registered to MM0FMF SMS Gateway, long time ago.
Let me try again…qrx
It is Ok now without the tick box (Phone registered)
Thanks for helping.
Have a nice Xmas evening Inigo
Go to your SW settings and untick the “Ignore test spots” that you must’ve ticked ages ago and forgotten about now you actually want to see a test spot
