I’m getting very lacklustre in my planning these days. I knew it was going to be a windy day, and having spent a couple of hours on Gummer’s How in the wind last weekend I wasn’t really in a hurry to repeat the experience. Even with a tarp the wind just somehow seems to drain your energy and warmth regardless.
However - the one saving grace today was that the wind was coming from the NE which meant I could setup on Gummer’s How facing the west - which was kind of the point of today’s event. Didn’t fancy my chances with the SOTABeams Band Hopper IV in these conditions, so I opted for the Chameleon MPAS2.0 - a first for me using it SOTA. It is very sturdy and provides a reasonable SWR match on 6m - 60m. Handy when you are hunting down S2S.
Equipment:
- IC-705
- 21AH LifePo4 Golf Cart Battery
- RM Italy HLA-150V amp
- Chameleon MPAS2.0
- DD Superlight Tarp
- Paper logging
Yes, this lot did weight some!
I opted for the Chameleon choked 50ft COAX so I had the option of separating operating position from antenna. As it happens I found a good rock with protection from the wind and managed to get the spike of the MPAS2.0 in about 1/2 way which was good enough to keep it vertical(-ish). The wind really gave it a hammering - the whole thing seemingly 20 degrees off vertical at times!
I was on the summit for around 2.5 hours and stayed long enough to see the sunset. By this time I was getting chilly and decided it was time to pack up. I spent plenty of time seeking out NA activators but wasn’t very successful - 15m & 18m seemed to be the best bands, and were definitely opening towards the end. 20m was hopeless transatlantic.
My CW skills would appear to have solidified a little and I didn’t need many repeats and only made one error - corrected by the other station before the QSO ended. Six S2S in total with @W4KAC Ken, @VA2EO Eric & @AJ2I Alfonse very welcome EU-NA S2S. Also of note was NG6R Jerry all the way from Long Beach, Los Angeles, NW7E in Oregon & @W7GA Greg in Salt Lake City - some good DX there into the USA!
10m was serving up some tantalising DX including The Falkland Islands, in the end I had to content myself with Western Sahara, Brazil and Israel.
TIME | CALLSIGN | BAND | MODE | RST | RSR | OPERATOR | SIG | REF |
16:33 | EA1DB | 20m | SSB | 59 | 55 | JESUS | ||
16:34 | MW0PJE/P | 20m | SSB | 52 | 53 | Pete | SOTA | GW/NW-043 |
16:34 | EA2DT | 20m | SSB | 57 | 57 | Manuel | ||
16:35 | SP9JKL | 20m | SSB | 59 | 58 | Jerzy | ||
16:35 | EA2EVM | 20m | SSB | 59 | 57 | Cesareo | ||
16:35 | LZ2HT/P | 20m | SSB | 59 | 57 | Ivan | WWFF | LZFF-0584 |
16:36 | HA7WA | 20m | SSB | 59 | 59 | Viktor | ||
16:37 | VE1PVH/P | 20m | SSB | 52 | 55 | Paul | ||
16:37 | OH3GZ | 20m | SSB | 59 | 59 | JUKKA | ||
16:37 | DL7CX | 20m | SSB | 57 | 53 | Dr. | ||
16:38 | IU3GKJ | 20m | SSB | 59 | 59 | Riccardo | ||
16:38 | GB20SOTA | 20m | SSB | 57 | 57 | Tom | SOTA | G/SP-015 |
16:39 | EA1AAP | 20m | SSB | 59 | 55 | Fernando | ||
16:39 | IN3ADF | 20m | SSB | 59 | 57 | Markus | ||
16:40 | OE2ADE | 20m | SSB | 59 | 55 | Andreas | ||
16:40 | OM1AX | 20m | SSB | 58 | 57 | VLADO | ||
16:41 | OE6RCD | 20m | SSB | 55 | 55 | ROLAND | ||
16:47 | HA7WA | 17m | SSB | 59 | 55 | Viktor | ||
16:53 | MW0KXN/P | 40m | SSB | 58 | 52 | Kevin | SOTA | GW/MW-021 |
16:54 | GW4VPX | 40m | SSB | 59 | 59 | ALLAN | ||
16:56 | MW0OFA | 40m | SSB | 59 | 59 | Frank | ||
17:00 | IH9YMC | 15m | SSB | 59 | 57 | Raf | ||
17:10 | WN4AT | 15m | CW | 559 | 599 | JOSEPH | ||
17:12 | K0BWR | 15m | CW | 559 | 599 | Steven | ||
17:13 | W4KAC/P | 15m | CW | 559 | 549 | KENNETH | SOTA | W4C/CM-007 |
17:20 | W7GA | 15m | CW | 559 | 449 | GREGORY | ||
17:23 | NG6R | 15m | CW | 599 | 539 | JERRY | ||
17:38 | VA2EO/P | 15m | CW | 559 | 539 | Eric | SOTA | VE2/ES-034 |
17:45 | G6LKB | 10m | SSB | 59 | 59 | David | ||
17:53 | 4Z5LA | 10m | SSB | 59 | 57 | Ros | ||
18:29 | S01WS | 10m | SSB | 59 | 59 | WESTERN | ||
18:49 | IZ6BXV | 17m | SSB | 59 | 59 | TONY | ||
18:59 | NW7E | 17m | SSB | 57 | 55 | Michael | ||
18:59 | AJ2I/P | 17m | SSB | 55 | 55 | Alfonse | SOTA | W2/NJ-008 |
19:07 | KD2WNY | 17m | SSB | 59 | 54 | Michael | ||
19:10 | PY2GJ | 17m | SSB | 59 | 57 | Marcelo |
Many thanks to all participants - sorry I missed the bulk of the EU activators!
