In reply to G6TUH:
Hi Mike, I was surprised that someone responded so quick after my first CQ.
Now looking on this forum I saw you passed 10k points last year, so you have “some” SOTA experience, especially on spotting.
Yes, I did put an alert for my estimated QRV and was lucky to find 14.280 free.
It was a fun activation, with some things/mistakes to learn from.
Next time I should have a WARC band antenna if a contest is running on same time.
Without an ATU and only a 7m fishpole I’m quite limited to a few antennas, mainly verticals or delta loop. I also need to research more about an antenna for the 40m band, so I can work also some close stations (YO, LZ, HA…)
I’m looking forward for more SOTA and YOFF activations.
Any advice are welcome.
In reply to YO8SEP:
Yes, as well as entering your activation QSOs - for each S2S QSO you need to enter a Chaser entry. Enter the details just as if you had chased the other station from your home QTH but you will see that there is a checkbox “Is QSO S2S?”. Check this box and you will be asked to enter your activation reference. Then your S2S will be fully logged!
I don’t have an antenna at Home QTH
From 5 S2S, 2 were from 2 operators from same SOTA. On the Chaser log the second QSO show points as: “0 ?]”. I suppose I don’t get points from same SOTA even than are from different ham activator.
In reply to YO8SEP:
Yes the Chaser points are for the summit. So you can only claim points for a summit once each day irrespective of who activated it.
