It has taken me a number of days to recover after my 3rd chemotherapy session, but I finally felt like going out to activate SOTA again today.
Despite having suffered, as a chaser, some extremely poor propagation conditions over the last days, I decided for an afternoon activation, although I knew it would be quite a struggle to get the QSOs in the log.
I chose this drive-up summit because I had not yet activated it this year and it was a perfect chance to collect 4 activator points.
>Me ha llevado unos dĂas recuperarme tras mi tercera sesiĂłn de quimioterapia, pero, finalmente, hoy me sentĂ con ganas de salir a activar otra vez.
A pesar de haber sufrido como cazador unas condiciones de propagaciĂłn extremadamente pobres en los Ăşltimos dĂas, decidĂ una activaciĂłn de tarde, aunque sabĂa que serĂa un tanto difĂcil conseguir QSOs en el log.
ElegĂ esta cima de las que se pueden subir en coche porque no la habĂa activado todavĂa este año y era la ocasiĂłn perfecta para recolectar 4 puntos de activador.
I setup like this in a clear area slightly below the very summit, which is quite full of boxwood.
>Instalé de esta manera en un claro ligeramente más abajo de la cima, que está bastante llena de boj.
The antena was a 21m long endfed wire as an inverted vee and a 6m long counterpoise wire laid on the ground.
The rig FT-817ND at 5 W.
>La antena fue un cable de 21m de largo alimentado en el extremo como una V invertida y un cable contraantena de 6m de largo descansando sobre el suelo.
I started CQing on 20m CW and logged 9 QSOs in 17 minutes.
After a number of unresponded CQ calls, I QSYed to SSB. On 14.305 I logged 5 QSOs in 9 minutes. 3 with Belgium and 2 with Germany. When nobody answered after a number of CQ calls, I decided to QSY to 30m. I got spotted on SOTAwatch but several CQ calls couldn’t bring a single chaser, so I got a null on 30m. Then I QSYed to 40m CW but I found contest activity there and I QSYed to SSB, although I confess that 40m SSB is not my favorite place to be when activating SOTA. There is just too much QRM and splatters from QRO stations for a tiny QRP signal like mine… I logged 3 QSOs here. First, I chased José EA7YT, who was CQing offering a municipality for the DME award. Then I moved to a clear frequency and called CQ SOTA, which brought 2 chasers, one EA7 and one OE.
I called CQ some more times with no answers and I decided to QRT because the Sun was quite low and the temperature had dropped with an increase of the wind and I had started experiencing one of the side effects of my chemotherapy under the cold, which produced pain in my fingers and hands like several thin needles were sticking into my fingers and hands skin.
>Empecé llamando CQ en 20m CW y anoté 9 QSOs en 17 minutos.
Tras algunas llamadas CQ sin respuesta, hice QSY a SSB. En 14.305 anotĂ© 5 QSOs en 9 minutos. 3 con BĂ©lgica y 2 con Alemania. Cuando nadie respondĂa tras algunas llamadas CQ, decidĂ hacer QSY a 30m. Fui anunciado en SOTAwatch pero muchas llamadas CQ no consiguieron traer un solo cazador, asĂ que tuve un cero 30m. Entonces hice QSY a 40m CW, pero encontrĂ© actividad de concurso allĂ e hice QSY a SSB, aunque confieso que 40m SSB no es mi lugar favorito para estar cuando activo SOTA. SĂmplemente hay demasiado QRM y splatter de estaciones QRO para una pequeña señal QRP como la mĂa… AnotĂ© 3 QSOs aquĂ. Primero cacĂ© a JosĂ© EA7YT, quien estaba llamando CQ ofreciendo un municipio para el diploma DME. Entonces me desplacĂ© a una frecuencia limpia y llamĂ© CQ SOTA, lo que trajo a 2 cazadores, un EA7 y un OE.
Llame CQ algunas veces más sin respuestas y decidĂ quedar QRT porque el Sol estaba bastante bajo y la temperatura habĂa caĂdo con un aumento del viento y habĂa empezado a experimentar uno de los efectos secundarios de la quimioterapia ante el frio, que produce dolor en mis dedos y manos como si tuviera muchas finas agujas clavándose en la piel de mis dedos y manos.
All in all, these 17 QSOs in the log:
>En total 17 QSOs en el log:
You can see it on the map:
>Pueden verlo en el mapa:
Before dismantling the setup, I took this picture for you to see how the light had dimished by that time.
>Antes de desmontar la instalaciĂłn, tomĂ© esta foto para que puedan ver cĂłmo habĂa disminuido la luz para esa hora.
I’ll be looking forward to copying you all again soon from another summit.
>Gracias estimados cazadores por sus llamadas y QSOs.
Estaré deseando copiarles pronto a todos ustedes de nuevo desde otra cima.
Guru
