Hi Andy;
Thanks for your comments.
Yes, I agree with you about the wider bandwidth making reading the cw easier, my normal choice would be Hz but I choose to reduce to 200Hz because unfortunately we have particularly on 40m some pretty wicked pile ups, always with tail enders and always with stations calling when they can’t hear the activator go back to a calling station.
Most chaser activity is not dead zero beat with the activator resulting in a spread of signals around the activators frequency, this is often deliberate as as an activator would find it almost impossible to pick out a call sign in a pile up if al the signals had the same tone.
The chasers being most times on 40m, very considerably stronger than the activator who is down in the noise. With the very sharp I.F. dsp filters in the FT2000 this enables me too most times cut out the tail enders and those that insist on calling blind and enable me to concentrate on listening for my call sign coming back from the activator,
One of the disadvantages I have found with I.F. dsp filtering in my case is that the nature of my noise is very naroow impulses which tend to sound like frying, the amplitude of theses pulse tends to be a lot of the time with very weak signals higher than the wanted signal, this results in the sampling A to D converting at that instant of time the pulse peak amplitude rather than the wanted signal, this results in an effect that sounds as if the wanted signal has had holes punched in the audio spectrum.
While I agree with you that monitoring the wanted signal on a spectrum analyser may help in reinforcing a weak signal in and out of the noise, I doubt without some considerable long mental programming that I would be able to obtain my reading of weak stations in the noise most times send at some 25 wpm and often faster.
There is also another mental filter that you have not mentioned which is very powerful, that is the ability to recognise your own and others callsigns in the noise and general back ground. This is very powerfull because it enables you to recognise your call sign by the rhythm even if bits of characters are missing.
I often sit doing something on the computer while the rig is on or around 7 032 with the headphones connected and lying on the desk and not consciously decoding the back ground cw stream coming to me at low levels when all of a sudden well known call signs like G4SSH just jump into my head and I then know that there is a new activation awaiting my attention that I have missed because I have not been consciously listening or monitoring Sotawatch.
This is obviously well know to ex commercial operators like Roy who spent many hours on radio watch and would not continuosly conciously decode the steady stream of traffic.
I appologise to those that may be offended by this long post which has gone a bit off topic but I feel that Sota is an activity that proves that CW is not redundant even if there are better ways of moving large amounts of information in the commercial world. I believe that Sota should actively encourage activators to progress from qualifying a summit with four contacts on an FM hand held to being heard by and chased by a wider audience.
73 de Ken G3XQE (closing down unintentional activation of CW soap box)
