Morserunner CE SOTA edition: release
G’day
I uploaded the forked Morserunner Community Edition code with the SOTA activation added to my Github. You can find source code in my Github. Linux and Windows binaries are here. The readme (frontpage) contains instructions how to compile the code yourself if you don’t like precompiled binaries. I have tested the code on Windows and Linux for about a week, and found no issues yet, but if you have any suggestions of problems, please drop a note. My email on qrz is good.
Thank to Mike W7SST and Alex VE3NEA for developing the original code.
73, Martin - PE1EEC.
Martin, I’ve used the standard Morserunner for years. Are you saying this version has a SOTA-activation friendly feature? Is that described elsewhere on this reflector. If not, would you summarise it here.
Thanks, Andy
Hi Andy.
I updated the readme.md, on github, but it looks like it is lost. Github is rocketscience, hi. It still only contains the compilation instructions for those who don’t like precompiled binaries.
Yes, this has SOTA added with callsigns of CW activators and chasers, and summits.
Best is to run in pileup mode with QRN, QSB, flutter and LID’s enabled and CW Max and Min speed to +10 and -10 (this at least reflects European reality in speeds, hi). QRM adds ops who call CQ over your frequency. I leave that off, but you could use it if you like to train on fighting in keeping a frequency during a contest.
Click Run and then call CQ.
Pressing spacebar moves to next field.
For chasers you only need to fill in the call and the RST. The Sent RST is “calculated” on the strength of the station. They might ask for your reference, then press F6 to send the reference. If copied, they sent TU 73. If they ask for NR (remember, this is a contest program, but I might remove that), press F2 to resend their RST. It tries to emulate what would happen if they receive you 339, so they might ask two or three times for the ref. The S-value is highlighted, so if you receive 549, you only need to type 4.
So in short, enter call, press space bar, enter RST, press enter, TU is sent and you’re ready for the next one.
For S2S simulation, the program will randomly pick a call with prefix and or suffix, and pretend it’s someone holidaying and doing SOTA. It then selects a summit-reference, matching their prefix. So as example a DLxYYY/P or a DL/FxYYY or a DL/DxYYY/P could be activating from DL, and if they are selected at random by the program as S2S, they get a DL/ summit assigned, and will send their reference-code immediatly after their RST. If you miss it, press F7 to repeat the RST + REF, of F8 to repeat the ref. For a valid exchange you need to add the hyphen!
The program has more features, but check the help for the original documentation.
Hope that helps to get you going
73, Martin - PE1EEC
Hi Martin, works great on my Linux machine! Thank you! The window for activity setting for example is not well readable, but that’s a small detail, perhaps due to my lo res screen. Not important.
I continue to wonder why the community edition has less realistic “band noise” compared to the original, almost too refined… But that’s not your port…
Very nice to have a real Linux version!
Peter. It seems the code for the audio-generation in VE3NEA and W7SST’s is the same. Maybe it’s a Linux thingy, or a setting, not sure. What happens if you start from scratch by renaming the .INI file?
I’m working on some cosmetic changes. One of them DPI-awareness. But I almost ran out of tokens tot test and verify on WIndows. That willbe for tomorrow. I also want to try and have it adjust to the system-mode darl/light. The program itself looks to be working fine with all the exchanges and requested repeats etc. For me it feels like I would run a SOTA-activation.
73, Martin - PE1EEC
Thanks for all your work Martin! Very useful edition! The original Morserunner has hardly any settings, the CE edition quite a bit. I guess it’s just me not having been patient to figure out the settings that reproduce the “original” I am used to…
73, Peter
I just installed and had a very brief (5 mins) play with the (Windows) MorseRunner CESOTA1.0, just to check it installed properly. The SOTA activation option looks very good. I look forward to exploring the SOTA features and perhaps to improve my pile-up handling capability.
