Morse training tools and regimes
Mark @M5TEA, you’re in luck!
You have the best free tools, and they’ll help you a lot.
  • DXlog.net (https://www.dxlog.net) This software is for contests. But it includes a simulator with the MorsuRunner engine integrated. It’s for practicing SO1R, SO2R, and 2BSIQ operating modes (in advanced scenarios). This simulator immerses you in a real pile-up operation. You can add difficulties (QRM, QRN, number of stations calling you, etc.). Of course, you can also adjust the speed. It’s fantastic!
  • RUFZ (https://www.rufzxp.net) Unlike DXlog.net, this software isn’t a simulator (it doesn’t add difficulties like QRM, QRN, pile-up, etc.). Its focus is on improving CW speed, particularly ultra-fast copying of real amateur radio callsigns. Its goal is to improve the operator’s performance in CW contests. Its operating system is simple and adaptive. Start by sending callsigns; if you get them right, the speed increases slightly; if you get them wrong, it decreases. It adapts to your progress. It’s a lot of fun!!!
If you aspire to participate someday in the IARU High-Speed ​​World Championship, you need this!!!
  • And finally, the best advice: Practice, practice… practice. I do it every day!!!
73 de Dani EA5M
I used mainly LCWO.net. Firstly in random groups then in callsign training. Got me to 15wpm at an OK rate. Then I went on the air a lot and gradually upped my speed. I did lots of lcwo.net callsign training and now the keyer is set to 20wpm but I can copy well sent code faster.
But… I cannot ragchew but only do contest/SOTA style exchanges. I should practice ragchewing.
The tried and tested method taught to most professional operators I’ve come across is pretty simple - with a few caveats:=
  1. I would NOT suggest using standard SOTA or the rubber stamp type QSOs you hear on the air. Unless thats all you intend ever to do you’ll trip up the minute someone goes ‘off script’ or sends you something you were not expecting.
  2. Practicing random English words/sentences etc., is fine. But doing so encourages you to guess what the next word is. And thats an error which will throw you off.
Use foreign language texts and random groups. (I guess random ham callsigns will do at a pinch. That way you’ll learn to read morse - any morse.
I wouldn’t use Farnsworth either. Its rarely heard ion the air.
  1. So start off using an overall speed (character & overall speed the same), until you are comfortable and achieve decent accuracy at that speed - say over 85%. Yes you’ll have to mark your own work, but guessing your accuracy will probably do. Once you are comfortable reading that morse at that speed, then increase the speed you are practicing on by 1 or 2 wpm. Repeat and keep practicing until you are comfortable at that new speed and your accuracy has increased - say of 85% again, and simply repeat until you’ve reached a speed you.
  2. ‘Head copy’ of plain language will simply happen once you’ve got comfortable receiving morse at your chosen target speed. Forget trying to do ‘Instant Character Recognition’ or ‘copying behind’. Both of these will happen and get better, anyway as you progress.
Many apps, such as Morse Runner, does random letters, random callsigns as do other apps, but I have never really used many so you’ll just have to search around the many apps.
LEARNING TO SEND GOOD MORSE
Almost every morse operator thinks their morse is good. But how do you know what your morse sounds like to others?. You cannot judge what your morse sounds like - only someone else can. You might think you are sending perfectly formed letters with correct spacing and correctly separated words but that is because you know what you thought you were sending.
To improve, you need to hear what your morse sounds like to others.
There are many apps that can read (good) morse but none will tell what you need to do to improve. Unless you know someone who will be able to give you feedback and constructive criticism I’d suggest the following method:-
Using your phone or some other device to record, play/send some of your morse and play it back so you can hear what you’ve sent. That works, sort of, except you are likely to remember or know what you were sending, so you won’t be able to judge the quality very well because you will have a built in bias and know what you were meant to be sending.
There are a couple of ways of avoiding this:-
Send random groups of letters or morse characters. Then playback what you sent and see if it matches what the groups/characters were.
Find some 'foreign language text and use that.
Or… if you can only find plain old English to send then wait until you’ve forgotten what you sent before playing it back to yourself… Sending English text backwards works much better. IE retteb hcum skrow sdrawkck…
Find a friend who does morse (on or off air) And get them to give you accurate/honest feedback.
Concentrate on reading morse…Thats listening to it and not reading about it.
Learning morse isn’t rocket science and you don’t need a degree - but you DO need to put time in. A few minutes a day is not enough AND you will benefit from feedback from good, competent operators. ~Not necessarily from others who are also learning.
  1. Dave Perry's logbook: Learning Morse in the Royal Navy
Hi Mark,
Pleasure to work you today, especially when I remembered who Tea was ha ha.
My fingers took over several times, making me back home rather than here in G/LD.
Farnsworth spacing helps (me) a lot too for example Maneul @EA2DT sends with a high character speed but nice spacing so it’s possible for old ears like mine to catch him. Esther @GI0AZA did the same today. Thanks!!
More opportunities tomorrow and Friday as I hope to get up some more little ‘uns and suspect that 2m fm ain’t gonna work too well. :blush:
Alan
yes, yes, yes :exclamation:
you think too much about speed, Farnsworth spacing (thanks to you I found out what it is :smiley:) and other theoretical things
just activate, activate, activate :exclamation:
73, Jarek
For those who use Linux:
  • Morserunner runs well under bottles or wine
  • Rufzxp is great but doesn’t run well. There is a Linux version called qrq which is good, written by Fabian DJ5CW, the author of LCWO.net
The G4FON Koch trainer worked for me and was free…still didn’t make me enjoy code!
Over the years I have had a few unexpected QSOs when using dummy loads!:rofl:
:raised_fist:
LCWO is very good. Particularly for head copy.
How did you get QSO’s on a dummy load!? :hushed_face:
Nah! Too often for busy folk. Better to set a realistic goal [10-20 minutes, 3 times a week] that people could stick to and not find a chore. I do Duolingo every day [so I don’t lose my streak] but frankly some days I just don’t feel like it. Just like physical training, you need a day off.
But very few people use Farnsworth spacing. I can’t say i’ve ever heard it used on the bands. You may just as well practice using regular/normal spacing until you can read it at that speed. If Manuel/EA2DT sent regular morse at, say 25wpm with normal spacing you won’t probably be able to read it.
If someone told me to QRS I’d assume that they want me to slow down and not to keep the character speed at one speed and the spacing at another.
I use it during my CQs with my callsign. I don’t want to keep changing the character speed of my KX2 [normally 18 or 19wpm] and I’m aware that there are quite a few QRS chasers who prefer to get my callsign correct the first time because I inject bigger spaces. In fact, when I hear their slow Morse overs, I match their overall word speed by sending bigger spaces.
No one ever asks me to QRS. In any case, I believe you always use a straight key - and at home where I have a SK, I do the same (i.e. slow the character speed), but with paddles I won’t. Most less-experienced CW ops need the extra thinking time between characters and don’t have a problem recognising characters sent a bit faster than they do.
David’s extremely informative post is really all you need to know. I don’t have a professional background in Morse Code but I have been using it more or less as my sole on the air mode for fast approaching 60 years. David has nailed it - I couldn’t have put it better.
I happened across EI7LC on 80m this evening - he runs the Nervous Novices CW Net that runs as slow as the slowest caller but I was pretty much on point at 12 wpm and it was great to be able to copy everything except during QSB. Great success (cue Borat).
I find during most random CW QSOs that folk tend to send at their natural speed, even if they slow down to start with. It’s quite demoralising when it ends up being a rubber stamp QSO regardless of how much info they send.
Thanks for all the suggestions hopefully they will be of use to other folk, and I’ll brave CW again on the next outing that I hope will be this weekend at some point if I can break away from the DIY.
I did nearly that when I got a 599 from Chris @F4WBN using the mountain topper from Pike O’Blisco (hope the LD area manager isn’t watching if I got that wrong) even though I hadn’t plugged the antenna in. 24 inches of coax and about 3w can get you a QSO when the ‘big guns’ are listening!
Mark
Eamonn is mega. I met him at the IRTS Hamfest this year. We did CW QSO’s there on 2m and 70cm!
270, what else? :face_blowing_a_kiss: :ok_hand:
Probably a bit of radiation from the patch lead, I doubt more than a few mW were radiated but its enough for a well equipped local to hear!
I need to practice my CW cos there are not many ops left to rag chew with in VK.
I like the Computer software Just Learn Morse Code.
I go on the SOTA reflector and find interesting topics to read and you can paste and copy a paragraph at a time into that software, set your Speed to what you can handle then lay back and listen to it doing head copy. A couple sessions per day is great not long but doing it often is the key.
regards Ian vk5cz ..
I can better that. F5PYI from a ZL summit on 5w with the antenna not connected to the transformer.
The power of contest-station chasers
It happens to me all the time. As a beginner, I set my speed to 15 WPM even though I can send at 20 WPM or more. Instead of changing their speed settings, people usually respond by adding extra spaces between letters, and that’s great, because I can copy at any speed as long as there are big gaps between the characters to process the information.
I use this very convenient website where your can adjust speed , recognition time , and many more … Word List Trainer | Morse Code World
I loaded SOTA callsigns in it and I do 10 min sessions from time to time.
That’s it, Wolf. And of course, our Manuel is involved. :clap:
Because as a beginner activator, it’s enough to simply return the call , RST and 73 for now.
Even the closest QSO is better for the chaser than none at all.
(I was just talking to myself. :thinking:)
