i wonder if anyone knows how to do a wide band mod for my “yeasu 920” please as i would like to get on 5mgs…thanks…paul.
In reply to GW0WTT:
Paul
Look back on reflector 2 days to title 5Mhz - there a description of the 920 mod near the end of that thread.
73 Glyn…GM4CFS
In reply to GW0WTT:
My Yaesu FT920 was UK purchased approx 8 years ago -
Have tried both mods:
'Cutting the green wire & powerup via 1984129 - no joy’
Also, expanded the menu and set the freqs to ‘Outside’ -
still with no joy’
The first worked for Roger, MW0IDX (tks fer info).
Anyone have other mods for 5mhz, please?
73s de Peter G3TJE+
thanks for the info,i would like to know what "Note: This mod is for Lot 8 and up " means as i bought the 920 when i came back on the air after a 10yr break and although i know its a great radio i do not know the history of it!
cheers paul.
- Remove top and bottom covers.
- Remove the DSP unit, and cut or remove the Green wire that connects
between R2544 and Q2510. - Replace the DSP Unit.
- Press and Hold STEP and LOCK buttons when powering on.
- Enter the following code: 1-9-8-4-1-2-9
- Test the radio for proper operation.
- Turn the radio off and replace the top and bottom covers.
- Mod is complete.
Note: This mod is for Lot 8 and up.
This mod will allow transmission on MARS and other frequencies.
If you do not operate MARS, then don’t do the mod.
