It has been a long time coming, but I feel ready to get out and about now with my Mobile chasing station using “Nora the Note”
Everything I do these days takes a lot longer, either r because I am slow at sorting things or waiting for a slot in the diary of an assistant.
So, First of choice of Radio, easy, My Yaesu FT857 perfect mobile shack in a box. All that was needed here was assistant with less shaky hands than mine to Modify for 60m. Sorted with help from my son finding me a slot in his busy diary. below before and after pics:
Next job, get it all hard wired into “Nora” done with some difficult manipulating of the Cockpit velour.
Decided after this that if I was to enter any Contests such as Backpackers or low power 144MHz then I would have a separate Car battery in the boot, to stop me running the car’s battery down.
Finally came the antennas, my initial thoughts were to fit a 3/8 Mount and an SO239 Mount, by drilling holes in “Nora’s” head near the rear hatch. This time I would need assistance from my very busy Mechanic and also felt a bit guilty for major surgery on poor Nora when she is quite well at the moment ![]()
Decided for the time being to use Mag Mounts. I have only ever used Sirio Mags in the past so 2 ordered.
Left hand pic shows HF Whip near the front and the 2m/70cm near the rear.
Right hand pic shows the 2m/70cm Whip again but this time with a 4m Whip built by my very good friend and Radio club colleague Steve M7HME.
I purchsed 4 HF whips all were AmPro Chinese copies for 60m,40m,20m and 17m. I was hoping to avoid having to use a ATU when Mobile, so using the old fashioned method of SWR meter in Line, popping in and out of the car to adjust each time. The 60m was 1:2 from factory so easy one there, 20m only took 2 small adjustments and again below 1:5, the 17m one slight adjust and again well below the happy stage.
The 40m was different story I have again spent too many hours in the last month trying to get it to tune, but will not go below 4. So back burner until I can get access to an analyser to test it thoroughly?
Finally and having a bit of patience, waiting for a 23cm Transverter from SG Labs to arrive shortly, I have plans to drive it with my FT817 so that I have multimode microwave facility. That has a UWB Log Periodic Antenna, 600MHz To 6000MHz 50W waiting for it in the shack.
So, here’s to my new adventure, Drive up the local high spot and chase the world
Thank you anyone who reads my post, and Activators get ready for my callsign and dulcet tones
Tony
