Mark spots as chased on SOTAWatch
Hi,
Would it be possible to add something to SOTAWatch to mark when we’ve chased someone ?
I’m thinking of a feature similar to Polo on the phone, where a spot appears crossed out once you’ve logged / chased it.
Or did I miss an existing option?
Thanks !
Click on Summits…
It’s not quite what I mean. I want to be able to see who I’ve chased today, live, directly on the SOTAWatch page.
It would be marked as “chased” as soon as your log contains the same combination of callsign + summit code within the same day.
For example, here I chased OE3KME on OE/NO-121, so the spot would now appear greyed out for me, even if the operator spots again on another band.
Do what I do check your Chaser log to see if you have worked them already.
Don - PLP.
Obviously… but it’s not what I’m asking sorry.
I think it is quite some extra demand for the database to handle those extra lookup tasks to check if you logged the summit+callsign combination already today.
So using a proper logging tool like PoLo or the successor HaLo - that also works on Linux, Windows and MacOS - might be something for you.
Oh nice ! I didn’t realise Polo had a desktop app. And with log sync too, pretty please !
I guess the only drawback is having to upload the logs every now and then…
https://spothole.app has a checkbox in the last column to mark spots as worked on current band and mode – do you mean s.th. like this? You can filter for SOTA-spots-only, but the marks are local knowledge of the browser(-session).
The idea is if you use the direct logging feature on sotawatch the system knows that you work the combination of callsign and summit. This way you could hide them from the list.
So you can avoid duplicate contacts.
Not sure how intense for the database but likely possible to program.
Maybe instead of marking the spots as “worked” , a side panel with “Who I’ve worked today” that doesnt refresh automatically with the spots, or something similar maybe less intensive on the database.
We may then get arguements about wha t “today” means with respect to times being logged in UTC.
For the SOTA points 00:00 UTC rollover is the relevant time so that you limit “one day”. But let’s see if Andrew picks up on the idea. I would even see a dedicted “logging” tab on sotawatch to make sense.
Use one of the many logging programs that integrate with the DX cluster. Add the SOTA cluster to your logging program then you can click on the spots in the logging program and work/log the station. Your logging program has a list of what you have just worked and you upload your log (CSV or ADIF) to the SOTA database once a day/week/month. All the software you need to do this exists for Windows, Linux and Mac.
Yes, visually it would look like that. But on the server side.
Ideally, I don’t want to use any program, I just want to log on the go from sotawatch. But if it’s not possible… then I will do without the feature or use Polo software :melting_face:
Well, you could just remember what you’ve chased. :wink:
It’s hard ! I’m losing it after 2 or 3 in a row :rofl:
Two browser tabs side by side…
Hi all :waving_hand:
I’m a bit like Remy, probably like Bob G3VXJ, trying to contact unique never before contacted in my log.
It’s a difficult task because it requires navigating the different pages of the website. The solutions proposed in the thread don’t satisfy me. HALO is under construction, etc…
I have an Excel file with nearly 13,000 entries that I update every evening. :face_with_peeking_eye:
It’s true that it’s easier to chase everything that passes through the cluster (see the table Sotadata3), and you’ll get an idea!
I’m in favor of not adding QRM to the activator frequency and making it easier for anyone who has never contacted the SOTA reference to do so… Yess I sometimes experience QRM because I use simple antennas and a power level relative to that of the activator! (5w to 50w)
A project that would allow users to see which SOTA have already been completed or not on SOTAWatch would be a great addition!
No Andy @GM4LLD don’t have a logger with the right cluster :wink: :grinning_face_with_smiling_eyes:
Un pavé dans la marre !
73, Éric F5JKK
Perhaps a script to edit your view in the browser utilising your unique chased summits with violetmonkey or similar.
My workflow: use HamAlert on my phone to get SOTA spot notifications. Use sotawatch to log when I have chased someone. In HamAlert, you click the spot and “mute callsign + summit” after you work them, and you will not get any more spot notifications from them. Easy and works well.
Another option is @ON6ZQ’s fantastic SOTAwatchfilter:
I had exacltly the same wish, thats why I made this:
It’s not SOTAwatch, but it shows which summits are already chased and which are potential completes after providing your activator/chaser log.
Have a look at the guide and feel free to give it a try.
Best, Matt
