What antenna is that?? sorry I may have misssed the post somewhere!
Thanks
Alan
Thanks
Alan
Hi Richard
I found another bug that affects this. There are two separate routes in the code to powering down.
I’m using LiPo cells and I will set my shutdown voltage to 3.6V in order to keep some buffer.
I have made a code change to remove this second version, currently testing, and will upload it to my github soon.
Cheers
Rick
Interesting. I would have thought 3.6 Volts was too high. Incidentally your low power code doesn’t appear to work on the Heltec V3 board that many are using. The WiFi ap part is fine but when the “low power” option is enabled from the web interface, the LoRa RX doesn’t seem to work.
any detailed info about it?
Hi Richard
I’m unable to test that as I don’t have one, but my changes shouldn’t have made any difference
Rick
Hi Ricardo
This change is this
Rick
I’m glad to inform that WebFlasher for LoRa APRS Tracker is now available for beta-testing (V0.9.8 ).
All boards should work right away. Enjoy!
https://richonguzman.github.io/lora-tracker-web-flasher/installer.html
send me the link please ![]()
Rick
Hi Richard
I may be wrong : I had commented out a chunk of Heltec code that was getting in the way of debugging - I have now out that back, so maybe you could try my latest version ?
Regards
Rick
is there a way to write you on telegram about this mods, looks awesome
Will do. I’m away at the moment.
Works like a charm!
Hmm, think ill just use the Jpole i had planned to use! certainly in the short term anyway… at the home QTH I have height on my side!
Alan
A matter of taste : 3.6V on a LiPo is around 15-20% depending on the cells - I’m using mismatched recycled vape ones that are probably best treated carefully.
Rick
There’s an interesting trade off there between battery capacity and solar panel size (if that’s your application). I reviewed the discharge curves I used and it does look like your suggestion of 3.6 Volts might be a good choice at low discharge rates.
Hi Richard
I’m experimenting with a 1.5W panel, which looks good so far for “super low power” mode
Will be using 5 mixed vape cells for around 6Ah capacity, so that should give ~ 10 days in the absence of sunlight.
It should be possible to make into a “single box” solution around 120x100x30mm - maybe with the antenna internal to the box ?
Rick
Anyone know what the teeny tiny co-ax connectors are called the use on the Heltec ETC LoRa boards??
Thanks muchly!
Alan
