It was relatively painless. I followed someone’s guide and then fixed the bits that had changed from when they wrote the guide.
sudo vi /etc/wpa_supplicant/wpa_supplicant.conf
country=GB
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
network={
ssid="SSID_OF_NETWORK"
psk="NETWORK_PASSWORD"
sudo vi /etc/network/interfaces
source-directory /etc/network/interfaces.d
auto lo
auto eth0
auto wlan0
auto uap0
iface eth0 inet dhcp
iface lo inet loopback
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
iface uap0 inet static
address 192.168.50.1
netmask 255.255.255.0
network 192.168.50.0
broadcast 192.168.50.255
gateway 192.168.50.1
sudo reboot
sudo apt-get install hostapd dnsmasq
sudo vi /etc/hostapd/hostapd.conf
interface=uap0
ssid=testPiAP
hw_mode=g
channel=11
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_passphrase=badpassword
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
sudo vi /etc/default/hostapd
DAEMON_CONF="/etc/hostapd/hostapd.conf"
sudo vi /usr/local/bin/hostapdstart
#!/bin/bash
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
iw dev wlan0 interface add uap0 type __ap
service dnsmasq restart
sysctl net.ipv4.ip_forward=1
iptables -t nat -A POSTROUTING -s 192.168.50.0/24 ! -d 192.168.50.0/24 -j MASQUERADE
ifup uap0
hostapd /etc/hostapd/hostapd.conf
chmod 775 /usr/local/bin/hostapdstart
sudo vi /etc/dnsmasq.conf
interface=lo,uap0
no-dhcp-interface=lo,wlan0
bind-interfaces
server=8.8.8.8
domain-needed
bogus-priv
dhcp-range=192.168.50.50,192.168.50.150,12h
sudo service dnsmasq start
sudo vi /etc/rc.local
/bin/bash /usr/local/bin/hostapdstart
Simples!
