Login problems
I have a new PC, and I am struggling to get logged in. I have changed my password, but it hasn’t resolved the issue. I think the initial problem was with Windows Security, but I have disabled it. What I end up with is either an incorrect username or password message, which is obviously incorrect. Only here with the last-chance saloon email link login, which only allows access to the reflector - nothing else
The reflector password is completely separate from all the other systems. Have you changed the right password?
Are you sure? I have always been able to log in to Sotlas, and I didn’t need to log in to this reflector, as it shares the same login. Logging in to the database takes me to the same login page as everything else!
Yes.
The reflector is one system with its own user name and password.
Everything else is SSO and use the same user name and password as each other. If you log on to one thing then you are also logged in to the other systems. But not the reflector.
You probably use the same user name on both systems and could use the same password. But they are separate logins.
Logged in to what? SSO?
Richard is correct. The reflector uses an entirely different account system for many (boring) reasons than SSO (database, sotawatch, sota maps, SOTL.as etc.)
Having looked, your SSO and reflector login usernames are completely different.
  1. Stop and think what you may have used for an SSO username (sotawatch, database etc.)
  2. Login using that as a username and the password you remember.
  3. If that does not work try a password reset using your username. If you have the correct username you will be emailed to the address registered.
  4. If that fails write out ten times on the back of a used £20 note “I must learn to manage my account information better.” and send me the £20 and I will fix it for you. :slight_smile:
Seriously, if you get stuck PM me and we can get you back online.
It’s been a slow day today, you are the first person who cannot login, I expect another 4-5 by the end of the week.
Could the username for the SSO be 2E0CPX?
that obviously was my old username but no that doesn’t work either. Just to clarify when I log into anything official SOTA this is the log in page.
Yes that is the SSO sign in page (sotawatch, database etc.)
It doesn’t work, even after I changed the password, I asked for my callsign to be changed, which you did, so something isn’t right
