That looks mega. Is that a selectable lead dial just above the grip? The rOtring is similar but the selector is at the top.
Do you find 0.9mm too fragile or not dark enough?
The "selector’ is so you can indicate what hardness lead you have loaded. The color of the hand grip rubber and the sticker on the eraser cap indicate the lead thickness.
The one weakness (literally) is that it’s only plastic between two aluminum tubes. This means the maximum leverage point is the weakest when there’s risk of bending. I’ve had two 0.5mm break from impacts/pressure to a backpack/pocket while in school. The 0.3mm has survived just fine and is my preference. I also fit 3 detailed QSO log entries stacked vertically on a single line of ruled paper, so it may not be for everyone.
…2B or not 2B, that is the question… ![]()
The rOtring is the same. Plastic body with metal grip and clutch. So is the Mars Technico, minus the selector dial.
The prices start to climb when you move up to full metal body mechanical pencils. All depends on your use case I suppose.
EDIT: Flagship rOtring is the 800. There is an 800+ with a touch tip for tablet use. It’s not cheap though, about £70/€80 rrp.
Oddly, the rOtring 600 is the mid tier pencil and comes in various limited editions and can command £100+ depending on rarity.
HB all the way! ![]()
I didn’t even realize
Of course this indicator has little utility for us mere SOTA activators. A nice and useful feature though is the possibility to retract the metal tip fully by pressing the hook.
Neither too fragile (never saw it broke) nor not black enough. It is just really good.
One drawback is the weight as it’s full metal; I don’t carry it on multi-day hikes (as I try to shave a few grams of most items in my bag).
I’m a phone logger since I started radio and I find it excellent. Soon or later I will try my first CW activation. And that’s a thing I’ve been thinking about. As a beginner in CW, sometimes I need to hear the call sign multiple times before I can decode it. On the paper it’s easy to write partial call signs and fill in the missing letters after a second round. I find this exercise very difficult on the phone. So when the day will come, I will also bring a piece of paper and a not so fancy pencil.
Hi Ian,
try this one or another one ! a lot with a paper !
For me using a Staedtler 2B or 3B is ok, but you know here not necessary a “Rain something” with Brexit too much expensive
maybe From US
Don’t forget the keyer ![]()
73, Eric
F5JKK
Yep! Pencil and paper (or a rollerball - in preference to gel and obviously fountain so it has less opportunity to bleed or smudge) all the time.
I use an app occasionally, though get flustered with it if things get busy - no chance in hell i will use an app for CW yet. Ham RS is alright but I like the one that bloke here has made:
If I don’t use it in the field, I tend to add my QSO’s in manually later as I like that it can export logs in different formats, versus having to do it all manually in QRZ.
Side note; what happened to fruit Polo’s? Or Lemon Polo’s for that matter? And while on the subject, you can never find red Bounty’s or Topic bars any more. Disgraceful.
@M5RJC Sounds fantastic. Any chance this is open-source and perhaps on github?
Yes, the dark chocolate ones, my all time favourite! Even the blue ones are not always available near me.
(Slightly OT, but Bountys are my SOTA comfort snack / emergency energy source of choice)
Ask the Swiss.
Over the years I found that I broke quite a few pencil leads. I’ve always struggled with handwriting and I developed a heavy handed style in order to maintain control of mark making. I am quite hard on pencil leads! I’ve tried a variety of mechanical pencils but by far my favourite is the PaperMate Non-Stop. The PaperMate Non-Stop suspends the lead in a loose spring, which provides two benefits; the lead is sprung, hence has a bit of give to prevent breakage, and, the lead is continuously adjustable so you can obtain the optimal length.
The PaperMate Non-Stop pencils are often discounted and come in various pack sizes. I have quite a number stashed away in my shack. ![]()
The older Non-Stop pencils were transparent, which aesthetically please me. My most treasured pencils are the clear orange ones, obviously! ![]()
I would like to, and I might in future, but it’s not release quality at the moment
I don’t want the support headaches that would come from releasing it part done
Not least it needs an import/export tool so that there are ways of getting data on and off the device other than direct to my database !
BTW it’s written in B4A (Basic4Android) - see https://www.b4x.com/b4a.html
But here are a couple of screenshots anyway
PS - a couple more features I forgot to mention
Cheers
Rick
Hello,
I made my own Android app, it has what I need:
Basically
it generates a valid adi for SOTA Database and for my log.
It has a quick callsign entry
it sends CW N1MM style, a video
and much more
you can try it and of course use it, the download link
I ever use paper log (blank paper, 2 pencils and knife, of course) and FLE when at home or in hotel.
I’m not able to hear CW, decode it and write on a Phone at the same time with my big fingers. With a blank paper I’ve more chance to correct and write again several times the calls, then report it on a paper log.
73 de Claudio
I made my own Android logger. It’s been working fine for 10 years.
I’m happy.
Dunno if my mind is going but I’m 14.833333recurring percent certain there was a Green Bounty as well?
Might very well have been a limited edition or something. Blue is the most common. Red, no sod has seen in the shops in about 90 years.
It’s like going on holidays to Cyprus and finding the local Safeway still sells Taboo and Mirage.
I had to research that. Blimey! ![]()
Same. Paper log all the way. Chuck it in an app afterwards and upload.
I carry two Pentel pencils and use a waterproof notebook. I transfer the log into PoLo then upload to the SOTA database later. It’s pretty quick.
I figure that I already have enough vulnerable tech with me to worry about for my activations and don’t want to add any more into the mix.
I am also one of these paper-bound QSO loggers, hi, and have been ever since I started using portable radio, long before SOTA.
So it is not surprising that during my first SOTA activation in 2012, a DIN A5 paper logbook from the USKA was used.
By the way, USKA has also been offering a paper logbook in A6 format for some time now.
Logbooks with USKA logo - now also in A6 format
Logging on paper also works when using the radio while standing, provided the station is compact enough and not too heavy to hold in one hand.
For this purpose, I have recently started using the 2 QRP setups shown below for portable radio during a break on my fitness hikes during the winter season, with a raised 4.50 m vertical antenna and T1 at the feed point (MTR3B on 30/20 m, QMX on 30/20/17/15 m).
