Logging out of Sotawatch & Sotadata
I can log out of the Reflector but not Sotawatch or Sotadata-any reason why I can’t?
Nope. Show me a screenshot of what you mean. (Reflector doesn’t use SSO, which SW3/SD3 do, so there’s the difference, but you should be able to logout of one and it logs you out of both).
When I click on log out, the screen blanks, then comes back & I’m still logged in. Just had an idea-I’ll switch my phone off & back on & see if that cures it. Watch this space…
I switched off & on & I was logged out, but after logging on again I can’t log off again.
I’m logged in to SOTAwatch and the SSO Admin console.
If I click logout on SOTAwatch, it looks like a logout happens, the username button turns back to a login button, the screen goes white and the you get logged back in.
If I click logout from the admin console, I get logged out and the login dialog appears.
If I am only logged in to SOTAwatch, then logout, the logout works.
If you have more than one tab open and logged in to the different SSO services then you get logged back in automatically when you logout. If you close the tabs till there is just one left, the logout works.
Well, no change. With Sotawatch (or Sotadata) the only tab open, I still can’t log out. The same applies to both my old iphone 6 & my new 15.
Ho hum, hopefully it may sort itself out, in time. Thanks for looking into things anyway, 73.
