Map is here: https://hf.dxview.org
Click on the map to choose your location and see the magic happen
- updates frequently
- similar to what I’m seeing in PSKReporter
Hi Brian, The site you are pointing to was already mentioned here:
But I’m still trying to work out if the mapping on dxview is purely based on spots on the clusters or data from worldwide Ionosondes, which this site uses: https://prop.kc2g.com/
THANKS, BRIAN!
You’re welcome!
Thank you for the links!
