Interested in what you use as a protective case for the Elecraft KX2
SideKX panels and cover and a small padded camera type bag (room for KX2, mic, power lead & in-ear buds).
Lowepro “Viewpoint CS 40” is the perfect lightweight snug fitting case.
73, Barry N1EU
I agree. Since I got my KX2 two years ago I’ve carried it in this bag on every SOTA activation.There’s room also for my Palm Nano paddles, KX2PD paddles [as backup], LiPo power cable, earphones and Velcro thigh strap/plate for paddles
SideKX panels and cover, then depending on the intended configuration either an OR Nalgene bottle case or a Tacticool water bottle case that holds radio, antenna, battery, external speaker, mic, power cable, earbuds.
It weighs just under 3 lbs and does well.
Malen
VE6VID
KX2
Unun with 9m coaxial and banana input
Spare Lipo accu
Palm Paddle
Ear buds
Throw weight
20m aerial wire with banana plug and 10m plastic cord and 20m at the end
2 pencils
Log book
List of my favorite calls
I use a Pelican 1120. It is a hard-case that offers good protection & is water-tight. It will hold a limited number of small extra bits, such as a small key & some connectors.
Rob - AE7AP
Hello
I can highly recommend the Lowe pro CS 80 bag. The KX 2 is well protected. It has enough space for everything. It is tidy…
