MM0EFI
1
The screen on my KX2 has started to display the CMP & ALC meter permanently and I can’t work out how to get it back to Power & SWR.
I’ve been through the menus and re-flashed the firmware. My guess is I have pressed a combination of buttons or that I’m just an idiot.
Any ideas?
IU1KGS
2
Hey Fraser, you didn’t mention if you already pushed the mic knob.
MM0EFI
3
Yes, I have pressed it. It cycles WPM <> MIC Gain and that’s all. A long press shows Power.
DL1CR
4
I remember that it was helpful to use AM mode to switch back to normal display mode.
IU1KGS
5
Then you might have cross mode enabled, it allows to transmit CW while listening in SSB, it’s hidden under the CW WGHT submenu
MM0EFI
6
Awesome Carlo! That’s exactly what it was. Now fixed.
Thank you
