IZ3GME
18 February 2017 23:50
1
The data center where the Italian sms spot gateway is installed is actually isolated from Internet so it won’t be able to publish the spots.
I expect the connection to be restored on Monday morning.
Sorry for the inconvenience.
73 de IZ3GME Marco
IZ3GME
21 February 2017 07:44
2
I’m glad to confirm that the gateway is online again.
best 73 de IZ3GME Marco
AB3TQ
21 February 2017 08:34
3
What is the local SMS Gateway phone number in Italy? Is the number the same across all of Europe, or is it different for most European countries?
IZ3GME
21 February 2017 12:36
4
The number is +39 366 2884598 and refer to an italian carrier.
There are similar gateways in other EU countries with their own numbers.
You can find more info here http://aripadova.it/contest/289-sota-spotsms-gateway.html
If you use Sota spotter app you can choose which gateway you want to sms to
73 de IZ3GME Marco
21 February 2017 13:29
5
It depends on which service you are using. There are several with different numbers and syntax.
