It was 20 years ago today....
13/10/2006 was my first SOTA activation on Tinto Hill GM/SS-064 with my late friend G(M)4ZRP. It really doesn’t feel like 20 years have passed.
That’s my 1998 vintage Mountain Hardwear fleece which is still in 99.5% perfect condition. I’m about 20-25kg lighter. And have much less hair and almost no pigment.
:birthday_cake:
Congratulations Andy…
Don PLP.
Ahhh the great Mr Black :frowning:
Here’s to the next 20 years! :wink:
It is good to see a photo of Brian. Sadly missed.
Great photo!
Sadly I think that’s one of the less desirable side effects of SOTA. It should really be one of the warnings on the home page (along with the benefits of course :wink:).
Congrats Andy, here’s to the next 20 :tumbler_glass:
Congrats on the milestone… a great picture too of the much missed Brain G4ZRP who I met several times and spoke to very often.
Gerald
I first met Brian via the same radio club as me. He would often be in my SOTA logs.
I missed chasing you that day Andy unfortunately. These are the stations I logged that day:
ScreenHunter 173
Our first QSO was on 18/12/06 on 60m on SSB when I chased you activating GM/SS-167 Black Hill.
Looking at my log you were very active in the latter part of 2006 and throughout 2007. All Qs were on 60m SSB. I realise now that you were one of the amateurs that didn’t have to pass a Morse test to operate on HF, so the carrot was not there, as it was for me in 1981 when I took my Morse Test in Liverpool. Every chance if Brian G4ZRP had to take a Morse test (I think he must have done) and he did it in Liverpool, he would have been tested by the same Marine Surveyor as I was - Mr Ernie Jardine.
73 Phil
Yes, he tested Brian.
I did a CW Test in 2003 to get M0 a few months before needing a CW pass was cancelled. I had great plans to use it but didn’t and had to relearn it in 2009. First CW activation proper was Ben Hope GM/NS-020 12-April-2009 where I managed 5 CW QSOs & 6 SSB QSOs. For me, using CW is just more pleasurable than voice or data. I still can’t rag chew on the key though.
Back to Mr. Jardine… Brian told me he turned up and was anxious but the guy was pleasant and asked Brian to have a practice sending to get used to the key then he said they’d try some practice receive sessions to help him relax, then they do the test. But after Brian had sent and done some receiving, Mr. Jardine said he’d passed as he was copying Jardine’s practice sending at 15wpm without issue but Brian’s sending was appalling. He told Brian something along the lines of “I expect you will not do much CW but you have obviously worked on receiving it. Your sending is appalling, don’t let me hear you ON MY BANDS sending that badly or there’ll be trouble.” I suppose Mr. J’s view was people need to be able to receive more than anything and Brian could do that faster than needed.
As for Black Hill in 2006, I can remember it as if it was yesterday. It was much further than I expected to walk or I was slower, both probably. I was late because of traffic and couldn’t find the track start. Anyway finally I found the track and was on the point of giving up many times as I was so unfit and so fat at the time. Eventually I got to the top and set up and wondered just how would things work with a newly made antenna on 60m. I had to wait for a QSO on 5.4035 to finish, I called CQ and was met with plenty of callers. Compared to how difficult 2m FM in the Edinburgh area was back then this was a revelation. I was so sweaty and hot after dragging my lardy body to the top I operated in a T-shirt. It was a stunningly sunny day but cold and at 1400Z the sun would be set in an hour. So by the time I finished the QSOs driven by adrenalin of climbing another hill and by how brilliant an inv-V dipole and 5W SSB worked on 60m I didn’t realise I was shivering. Fleece on, pack up and descend back to the road and then a few km back along the road in the last remaining light. The car was covered in ice when I got back and I sat in it with the heater blasting away to get warm.
And I left the camera in the car so there are only the images and sounds burned into my mind which is a shame. But without looking at the log I can clearly remember working you, Don G0RQL, Frank G3RMD, Paul G0HNW and Brian G4ZRP plus others. That’s how impressed I was with SOTA and 60m all those years ago. It had sufficient effect on me I still activate!
You’ve infected me with nostalgia, Andy! I looked out my logbook for 2006 to see if I worked you on that activation, but my only chase that day was G4BVE, 60m on SP012. Now thoroughly into a nostalgia kick I then looked out my logbook for 2003, the year I returned to ham radio after a decade off. At that time still a B license I was thoroughly into 6m SSB, amazed at the DX I could work with 5 watts and a long wire, but reading through the log (and seeing several auroral openings!) I actually discovered three chases that I had missed when I later discovered SOTA. I know they were valid chases because though I hadn’t understood the significance I had noted down the summit designations that the activators had given out, two were Bardon Hill CE-004, the third Aran Fawddwy NW-007. I don’t know if it would be possible to insert them in the record after such a long time. Anyway, thanks for inspiring a pleasant hour of nostalgia!
