Is anyone else getting errors while trying to upload logs through the sota data site ?
I’ve tried uploading a few times over the last 3 days, I keep getting an errror has occured message from the site.
Cheers
VA7XCW
Hi,
I loaded a file a couple of hours ago with no issues.
Take it you’ve tried the usual “help” desk approach of re-logging in etc?
Alan
Hi,
Take a screenshot or copy the error message and post it here. Otherwise noone can find the reason.
https://status.sota.org.uk/
Looks fine so systems should be fine.
73 Joe
Any chance you could say what the error message says? Or shall we just try and guess?
I run into problems also and SO FAR, the problems have been between MY ears.
A missing comma, a period instead of a comma, an “O” instead of a zero, unbalanced quote
marks… have been the problem. “Log Converter” from the “Cabrillo Doctor” suite of software
is a quick way to sort our problems.
Contest LogChecker Downloads (I have no affiliation with Cabrillo Doctor, just a user)
Good Luck
Carl WB0CFF
Just a reminder: if you need support on issues like this then use the ‘Contact SOTA’ form.
https://www.sota.org.uk/Contact
Include as much information as possible so we can help you quickly and efficiently.
Thanks,
-Josh WU7H
