Trying to upload a 33k .gpx file to SMP. The individual waypoints show up but when I click IMPORT nothing happens. Any ideas?
GPX File:
GPX File:
33kb but only 429 points sounds a bit strange. I would expect a lot more.
Can’t download it from googledrive (no access).
But I would recommend to push it thru GPSbabel
https://www.gpsbabel.org/
in the filters options reduce it to 250 points or so and output again as .gpx
Maybe this will help.
Or if it is a route and not a track try converting it to a track. Theoretically both should work but I recall routes sometimes are causing such issues on SMP.
I completely forgot that I drew this out in Garmin Connect and it would be a route not a track. Converted to a track and everything worked. Thanks!
