Hi Takeo,
I’m not an expert in this area but one basic question - are you logged into the system? Many functions in SMP only work if you are logged in.
Hi there, neither a region nor a summit have been selected. First after logging in is to select a summit via the 3 pulldown menus.
73, DIZ
Hi Ed, yes I´m logged.
Hi Diz.
After select the Association (Japan) that immediately appears in the following chart. It happens with some others associations.
Looks like something screwy in the sync. No errors in the logs, but the table seems shorter than it should be. I’ve kicked off the sync again.
Thanks, Andrew. Now it`s working.
73, Takeo
