We will be in / on Isle of Skye in July for a few days
Actual plan is
QTH > Loch Lomand (Monday overnight) > Isle of Skye > Glasgow (Friday overnight) > QTH
Looking at options for SOTA activatons
Are there any easy / short walk SOTA summits on skye? that maybe don’t require navigating wait high heather/boggy areas ?
I did look for routes but there are not a lot of them.
Ben Aslak GM/SI-041 took me about 1 hr 20 mins from the road over to the Glenelg ferry. It wasn’t too boggy and had spectacular views, not sure if that’s too long though.
The easiest two are to take the 15minute electric Ferry to Isle of Raasay and do Dun Caan GM/SI-092 and Beinn na h-Iolaire GM/SI-176. I’ve done both and they are simple. And you get to activate a less well known island.
On Skye, Ben Tianavaig GM/SI-105 looks straightforward with paths and parking. Sithean Bhealaich Chumhaing GM/SI-115 looks easy enough too. There is also The Storr GM/SI-028 which is a bit more effort but there are a zillion paths to the top.
If you look at Sotl.as you’ll find some summits which haven’t been on the air for 19 years. It’s not they’re super tricky just there are more famous summits with higher scores that tend to tempt people. Me, I’d like to think putting something on the air which hasn’t been activated for 19 years could generate a better pileup than something that’s on the air once a week. YMMV
Is this next week John? Just wondering as I will be on the island and will hopefully manage a couple of summits, though it is very much a holiday rather than a serious SOTA outing. I need to obtain the appropriate pass-outs.
Easier low hanging fruit are GM/SI-151, GM/SS-155 and GM/SI-161 in the south, GM/SI-104 and GM/SI-158 in the east central area and GM/SI-096, GM/SI-128 and GM/SI-152 in the west central area. However, I suspect you’ll be heading further north to see the falls and rock formations, so you might consider GM/SI-058 if you are walking the Quiraing. Other summits are available of course… Cuillins anyone?
Cheers for this list of hills. I will have a look.
We are travelling up 14th July.
I can get away with hills that are a short walk but I don’t really want to leave Mrs Vaz sitting in the car for a couple of hours as she isn’t a great fan of hill walking.
So far the only thing we have arranged is a meal at Loch Bay and a visit to Talisker
Ben Na Cro GM/SI-048 from then Torrin side is an easy walk, I did it in January with a snow on the ground. Although we were staying in a cottage in Torrin and so it was only 5-10 min drive to the start.
I have just uploaded the route to SOTA mapping.
Drove past Roineval GM/SI-096 yesterday and noted the layby to the south of the track up Meadale (NG391349) is blocked off. The lay-by south of there (NG397338) looks clear, but that adds a 1km road walk to the Meadale track or a more direct approach is required. There appear to be logging operations in the area which might compromise the track anyway. Probably too far for what you intend… 1km Road + 2.5km track + 1km rough ground to summit. 9km overall.
Meall a’ Mhaoil GM/SI-158 is only a steep tussocky ascent of just over 1km from the end of the forestry track (NG560303)… if you are fit enough.
