Irish Islands
From looking at the amateur radio licensing regulations for Republic of Ireland (EI), the prefix you are meant to use for the Irish Islands is EJ, not EI. However I have noticed some SOTA activations logged on these Irish islands where the EI prefix has been used rather than the EJ prefix which questions as to whether or not these SOTA activations would actually be valid because the wrong prefix was used. It’s most likely that SOTA activators using the EI prefix rather than the EJ prefix when activating SOTA summits on the Irish islands may have not been aware that the EJ prefix was meant to be used rather than the EI prefix, however when you are operating overseas you should be finding out what the licensing regulations are and what prefix you are meant to be using also. Any local knowledge on this would be appreciated.
Jimmy M0HGY
The following source is a good start I guess:
http://hamradio.ie/course-guide/modules/A2_Operating_Rules_and_Procedures/a2_3.html
For stations operating from offshore islands the prefix EJ (“Echo Juliett”) is substituted for the prefix EI
You list them and I’ll be happy to delete them Jim. And all the other incorrect CEPT operations.
Ignorance of the law is no excuse. Maybe a purge would encourage people to make an effort and learn the rules?
The usually well researched DARC CEPT List also has no info on that “exception”. I have contacted the author and provided this information.
Maybe such activators maybe read this thread Andy and decide to to delete the activations themselves based on this. Best to give them a chance first before I let you know the callsigns of such activators along with the such activations themselves. I certainly won’t listing such activations or callsigns on this thread either as this is just asking for trouble. Also I believe that chases and SWLs for such activations would have to be deleted also.
Jimmy M0HGY
Jimmy,
Yes, the correct prefix for offshore islands is EJ not EI. I see Esther and Ian have been using EJ today from Aranmore island. It must be lovely out there at the moment!
One minor grey area - I am assuming that EI is correct for islands connected to the mainland by road, e.g. Valentia or Achill - certainly all the logged activations are EI.
John EI3KA
I am not 100% sure for Irish Islands that are connected by road or cable car (eg Dursey Island) etc if the EI prefix or the EJ prefix should be used on such licences. Might be worth checking with the Irish licencing bodies.
Jimmy M0HGY
For visitors holding a primary license from elsewhere and enjoying reciprocal privileges under CEPT T/R 61-01 (such this Yank when I visit Ireland), the ComReg authority mentions “EI/ home call-sign” without note of whether the operation is from an offshore island.
While I can see that a standard Irish callsign is to be modified in this way (section 4.2 of the PDF), I’m not sure that it would be correct to say that the regulations would require me to use EJ/WN3F rather than EI/WN3F when on an offshore Irish island.
It’s EJ/homecall for the islands.
Yes, but the point that this is not explicitly stated in the official document (Comreg) is valid.
"• Visiting Ireland / Reciprocal Licences
TR/61-01 Signatories
non Novice or Intermediate Licence
EI/ home call-sign"
That’s what it says; no mention of EJ for islands.
It’s worth reminding visitors of the convention, and worth ensuring it is clearly stated in the ARM (I haven’t checked). However, using EI/homecall from an offshore island of Ireland, does not appear to transgress any law; just the convention. I personally think it would be unfair to deem such activations as invalid.
I agree that it would probably be unfair to invalidate any activations, particularly those by visiting hams. The ARM doesn’t explicitly mention this requirement, only referring to Comreg and to T/R 61-01 for guidance.
On the other hand CEPT Recommendation T/R 61-01 does explicitly state the requirement on Page 6 (Annex 5, 2016)…
The bit you have circled says “may be assigned”. Sounds optional.
Deleting logs isn’t in the spirit of SOTA or amateur radio in this instance.
No it’s explicit, the EJ is for islands and the “may also” bit means that Comreg can assign it to non island base calls in special cases much like UK hams can use GR/MR/2R till the end of June to celebrate the coronation.
Disagree Andy. The wording implies that EJ is available for use for islands and special events without any suggestion it is the only prefix to be used in such circumstances. Other official documents referenced above actually state visitors use EI/home call and don’t mention the islands case.
I think the criteria for using EJ is ambiguous. “Special prefix” has different meanings. It could be an optional prefix (along the lines of the additional Q and R prefixes we have seen in Britain recently) or it could be a requirement for these “special” cases. There is also the ambiguity about connected islands such as Achill and Valentia.
Until that can be clarified it would be unduly harsh to delete all contacts that have used EI from the island (and even then shouldn’t be applied retrospectively).
I agree @M1EYP Tom, that’s how I read it too! ‘May also be assigned’ is the strong sentence!
Come on folks, SOTA is a great amateur radio hobby! We don’t need to many politics added to the mix - always ends up pear shaped from my experience. Keep it simple and have FUN! :slight_smile: The documentation isn’t black and white, so using either prefix looks to be a successful activation. You can’t expect to delete anybody’s logs in this case - if it had been me using EI, I would be pretty damn cross having to delete anything!
73, Ben
GW4BML
From CEPT TR 61/01 - as indicated by John EI3KA, point 9 related just to the EJ prefix says:
9: EJ is a special prefix for offshore islands and may also be assigned, at ComReg’s discretion, to Special National Events.
If we take this as two statements as it is intended to be read I believe, we get
EJ may also be assigned, at ComReg’s discretion, to Special National Events.
So the CEPT document is in line with the local COMREG rules.
Although countries sign up for the CEPT agreements and therefore commit to them, local rules can always override the CEPT rules, so it is always best to check local regulations when wishing to operate abroad.
I agree with Tom however, that deleting contacts made by stations using the EI prefix on a SOTA EI (offshore) summit when they should have been using an EJ prefix is too harsh. Perhaps any operators who have done this could simply update their submitted activator log and contact his/her chasers to update their logs.
This sounds to me like an honest mistake.
Thanks to Jimmy for pointing this out for any future Irish Island activators.
SOTA is meant to be just a bit of fun…please don’t ruin it by needlessly deleting activations for this, or any other similar very minor transgression.
If the qso was from amateur to amateur, and conducted in good faith at both ends, then please just let it sand.
Ding! Ding! We have a winner. Nice to find someone else who can read and comprehend.
EJ is a special prefix for offshore islands… where does it state you have to use EJ on an offshore island?? This just mentions it is a special prefix you can use!
EJ may also be assigned, at ComReg’s discretion, to Special National Events… again, EJ MAY also be assigned, at ComReg’s discretion, to Special National Events doesn’t give a clear explanation.
So, as mentioned in my previous post… nothing is clear enough to delete anyone’s logs! KEEP SOTA A HOBBY!
