Today I had an incorrect spot from RBNHole. On 20m I was correctly spotted at 10:27 on 14.0619MHz but another spot appeared at 10:34 on 14.0603MHz. Obviously this is due to an incorrect spot coming in from the RBN, however at the same time there was another spot on 14.0619MHz. RBNHole picked the spot with the higher SNR but perhaps it could apply some more error checking and take a vote between the incoming spots. The same thing happened last week.
Better to contact the Skimmer producing off frequency results. If it’s wrong for you it will be wrong for others.
