Hi Ron
I used your guidance to perform some Resistance measurements using a DMM
Since this is a packaged, 2x MOSFET device and has a common source (the gold color base), the gate1 (A) and gate 2 (B) and the top two terminals, the drain1 (C) and drain2 (D) are the bottom two terminals, here are the values i get -
R(source-drain1)=8 ohms [this doesn’t seem to be high value resistance]
R(source-drain2)=1 ohm [this doesn’t seem to be high value resistance]
R(gate-source1) =infinity [this is open circuit]
R(gate-source2)=568 ohms [doesn’t seem like open circuit]
R(gate-drain1) = 1326 ohms [doesn’t seem like open circuit]
R(gate-drain2)= 439 ohms [doesn’t seem like open circuit]
Seems like the FET has ended its life?
I have already pulled it out and awaiting a new FET arrival.
I will repeat the above measurement on this new device, before i install.
