Anyone got any suggestions for a reasonably priced HF amp that will work at QRP input levels. I wanted to build the HF Packer amp, but it’s out of stock.
Andrew
Andrew
In reply to KC2EUS:
Hi Andrew
See here.: http://www.ha5iw.hu/
2-5W in, max 110W out. PTT, RF VOX.
price 36.000 HUF and post
Have PA for FT-817 and Rockmite too.
Feri
In reply to KC2EUS:
http://www.kn-electronic.de/Bausaetze/FET-PA25.html
Same with Rx/Tx switch, case and filters:
…produces 10W at 12V supply, 20…25W at 2x12V and 50W at 34V.
The push-pull design should give you better efficiency.
Regards,
Gerd.
In reply to DF9TS:
I bought myself a KL150 Linear for my 817 a couple of years ago, these are cheap and while they do work on the higher bands they are somewhat nasty! I wouldnt use one from home, i found i was taking too much gear with me onto summits so i adopted the policy of concentrating on getting the antenna right. Sean M0GIA
In reply to KC2EUS:
Hi Andrew.
You may google for the RM Italy HLA-300V at $352.00.
I have not used it myself.
Mike
In reply to M0GIA:
Yeah, I’m not too keen on the RM amps … I agree the antenna route is the way to go.
I was just looking for 10 or 20W … and I’m hankering to build a kit, so looking for an excuse to build something
Andrew KC2EUS / GM1YMI
In reply to KC2EUS:
Have a look at John GM8OTI’s homebrew amp for HF. He’s used this on a few SOTA activations.
http://www.marwynandjohn.org.uk/GM8OTI/projHFqrplinear.html
The HF Pack amp looks easy to knock off. parstandkits.com has 10 watts far $48 plus another $8 per band for the filters. I’ve built their filter kits and their audio amp and I have their 5W cw amp still in the bag. Good items.
In reply to KI6MWN:
Thanks that looks good, and the right price
