Hoping to activate G/DC-008 this morning on the trip home. Time not set in stone but between 10:00 and 12:00 UK time. Starting on 2m FM and might move to HF if contacts dry up.
cheers
john
M0VAZ
cheers
john
M0VAZ
Hi John,
I guess you are aware how alerts (and spots) on Sotawatch work? This would be the better way than starting a new thread on the reflector.
Enjoy the activation
73 Joe
This should really be an alert. People don’t read the reflector looking for activation info, they check the alerts table.
Thanks. All noted. No joy on the hill
There is a G3 magnetic storm in progress, see the other thread by HB9EAJ
Cheers for the info. I did scan around the HF bands and thought it was quiet.
I was out of the house this morning so couldn’t help.
As you will know 2m can be difficult down here - it can be done but generally weekends are better. Alternatively, some advertising on here helps as I’ve discovered.
As I pointed out above, that should mean using the Alert system and NOT posting reflector messages (unless it’s a special event or similar).
Id have to disagree. If I’m planning a 2 m activation from a remote location, I’ll occasionally drum up some support by posting a pre-planning post, and tweeting, and messaging everyone I know.
Every little helps!
Of course, now John @M0VAZ will have to write a report to follow up!
I would do the same in case I would anticipate a challenging activation. But in addition to, not instead of posting an alert.
