Ham2K Portable Logger (Android / Apple) for SOTA
Do you have a paid QRZ.com subscription? This is required in order for lookups to include locator grid. See PoLo mapping
As far as I understood you have 100 lookups per day for free. You can see that in your QRZ.com account details.
But in the recent November release the center of the country is used for the QSO map when no detailed data on location (entered grid, summit ref, pota ref) are available.
Yes, but it’s also limited to a subset of the data. Can see an example to demonstrate this in PoLo docs.
I see. Thanks Steven.
Don’t care to much about the locators and the map so I am fine with the free account so far.
Information that is provided for free should be free and not behind a paywall. That why I prefere
https://www.hamqth.com/
offering a free API for integration.
73 Joe
Interesting that it requires a paid subscription for that feature, it worked for months but I’ve never given them a dime. Certainly not something I’m willing to pay for monthly. Thanks for the responses.
Perhaps the developer of Polo may wish add a an option in the app configuration page to disable the map display.
I’m not interested in the Polo map function, I find the SOTA map attached to the SOTA log is adequate for my interests.
Andrew VK1AD
I would not want to remove it. Not everything needs a black or white solution.
We are all free to use and enjoy it or ignore it.
If one needs an analyzer of adif data I can recommend
http://analyzer.adventureradio.de
73 Joe
Enabling or disabling (not remove) a feature demonstrates an understanding of user preferences.
Andrew VK1AD
I agree. But as a programmer of a software or tool there is a personal sweet spot of what makes sense and what not.
So I guess we will let Sebastian make up his mind and come up with a clever soluation.
Btw there is already an additional datasource included next to QRZ.com that would work well for calls from certain countries.
Thankful for what is available and curious to what the future developments will bring.
73 Joe
I’d be interested in HamQTH as well. Now SebastiĆ”n has added hooks for extra look ups, like HamDB, this should be easier to add now. I’ll have to take a look at adding it.
Not sure if it’s an issue or just bad luck, but the self-spotting function has been very unreliable during my last activation. I was only able to self-spot once out of four, despite trying about 10 times each. The cell phone network was mediocre, but I had no problem accessing the SOTAWatch website and spotting myself.
Hi Stephan thank you for this Info, unfortunately this option did not show up on my installation, after uninstalling and reinstalling it showed up.
73 de hb9fvk
Hi Ruedi, thanks for your feedback and good to hear!
BTW: Yesterday evening I changed the download URL to https://www.qsl.net/hb9eaj/download/names.txt.
Now the updated version will always stay there, no need to change the Wordpress paths anymore :smiley:.
Same goes for the names.csv file, both can be downloaded directly from https://www.qsl.net/hb9eaj/.
73 Stephan
Could this be something to do with GMA cluster? I think WWFF has same troubles time to time and it uses the CQGMA cluster.
I think PoLo is just absolutely great app for activations. I use it on iPhone together with Logitech Pebble keyboard (lightweight and quite small but enough big for nice typing).
I don’t know whether this has been mentioned already in the thread, but I thought I would add it just in case. I used Ham2K Polo on an activation a couple of days ago and uploaded the ADIF file to SOTAData but it was missing the sent and received signal in the ā€œCommentsā€ column when I verified the log before committing it. I thought this was strange since I used Polo at the end of 2024 (I’m an infrequent activator) and the signal reports were automatically added when I uploaded the ADIF file from that activation (see https://www.sotadata.org.uk/en/logs/activation/1030372). Anyway, a quick message on the Ham2K Polo forum and it was sorted: I needed to modify the SOTA export template as follows:
Go to General Settings|Export Settings, then tap SOTA activation (ADIF)
Enable Custom Templates
Then in the ā€œADIF QSO Commentsā€ field either leave {{qso.notes}} and add the following {{qso.our.sent}} {{qso.their.sent}}, or remove it and replace it with
{{qso.our.sent}} {{qso.their.sent}}.
In the end I set the field to s{{qso.our.sent}} r{{qso.their.sent}} giving this result: https://www.sotadata.org.uk/en/logs/activation/1113426.
Hope this may help someone. Overall, I do like the simplicity of this logger.
It certainly has! I didn’t know I could add these fields!! Thanks
Edit: I’ve just made the change and deleted and uploaded my most recent activation… worked a treat!
