Gummers How
WOTA ID: LDO-067 | Height: 321 m (1053 ft) |
SOTA ID: G/LD-050 | Grid ref: SD390884 |
QTH Locator: IO84MG | |
Lat: 54.287427 Long: -2.937165 |
Following various changes in my family requirements this morning I wasn’t able to head to the planned summit Red Screes G/LD-017 as I was running about an hour late, so I opted instead to bring out the big guns FT-857D and the trusted SOTABeams Band Hopper IV (with an additional section for 60m) and head for my go-to local summit Gummer’s How G/LD-050. I think this is my 38th activation of that summit.
Thankfully the wind stayed much calmer than predicted and only after 3 hours did I finally deploy the tarpaulin to get some protection from the strengthening wind.
This is a popular family summit as you have a good head start from the road on the height and it has lovely views of the Lake District Fells and also Morecambe Bay and The Pennines to the East. I had to break off the radio many times to explain what I was up to, everyone was very interested.
Obviously the main focus was looking out for @EA2IF Guru’s spot and I managed to get him in the log on 30m CW after an hour on the summit. Bands were weird - it didn’t really open to the USA although there were some big stations making it through. As I am close to my 2,500 S2S points I concentrated on both working a frequency and also doing the crocodile-clip shuffle on the antenna to try not to miss an opportunity. There was no propagation to Scandinavia and other parts of Europe, but even so I did manage to get a healthy 19 S2S, so thank you to everyone who made the effort. What was also clear was that SOTA folk who were unable to head to a summit today were on the radio from home, a wonderful group effort.
TIME | CALLSIGN | BAND | MODE | RST | RSR | OPERATOR | SIG | REF |
11:58 | EA2WX/P | 20m | CW | 599 | 599 | Marcial | SOTA | EA1/BU-071 |
12:03 | DF1AKR/P | 20m | SSB | 55 | 59 | Andreas | SOTA | DM/BW-193 |
12:05 | 2E0HPI/P | 40m | SSB | 53 | 59 | Carl | HEMA | G/HTW-005 |
12:09 | 2E0GVI | 40m | SSB | 59 | 59 | Stuart | ||
12:11 | GM6ZAK | 40m | SSB | 59 | 59 | Andy | ||
12:13 | G3TQQ/P | 40m | SSB | 58 | 57 | J | SOTA | G/TW-004 |
12:14 | G4OOE | 40m | SSB | 59 | 59 | A.R.N. | ||
12:14 | DJ5AV | 40m | SSB | 58 | 56 | Michael | ||
12:14 | G6LKB | 40m | SSB | 59 | 59 | David | ||
12:15 | HB9JOE | 40m | SSB | 59 | 57 | ANDREAS | ||
12:17 | IU2HEE | 40m | SSB | 44 | 55 | Marco | ||
12:17 | ON7TWA/M | 40m | SSB | 58 | 59 | Geert | ||
12:19 | PD7P | 40m | SSB | 59 | 59 | Paul | ||
12:22 | S57LXN/P | 20m | SSB | 58 | 56 | Boyan | SOTA | S5/RG-016 |
12:26 | CT2IQK | 20m | SSB | 55 | 55 | Jorge | ||
12:26 | SQ9MDF | 20m | SSB | 59 | 55 | Leszek | ||
12:26 | SQ9NOT | 20m | SSB | 59 | 55 | WIOLETTA | ||
12:27 | S52CU | 20m | SSB | 56 | 58 | Mirko | ||
12:27 | SQ2NBY/P | 20m | SSB | 55 | 57 | |||
12:28 | CT1DIZ | 20m | SSB | 58 | 57 | JOSE | ||
12:28 | IN3ADF/P | 20m | SSB | 59 | 59 | Markus | SOTA | I/AA-186 |
12:29 | CT2HKN | 20m | SSB | 56 | 56 | Miguel | ||
12:30 | OE6GND | 20m | SSB | 59 | 59 | GERHARD | ||
12:31 | SP2SJ/P | 20m | SSB | 58 | 57 | MARCIN | ||
12:32 | SQ9BQW/P | 20m | SSB | 59 | 59 | Wojciech | SOTA | SP/BZ-065 |
12:37 | GM3YXM | 60m | SSB | 59 | 59 | Dave | ||
12:38 | G0EVV/P | 60m | SSB | 59 | 59 | DI | SOTA | G/SB-006 |
12:38 | G3RDQ | 60m | SSB | 59 | 59 | DAVID | ||
12:39 | G4IVV | 60m | SSB | 59 | 59 | Jonathan | ||
12:39 | GM4WHA | 60m | SSB | 59 | 59 | GEOFF | ||
12:40 | G4IPB | 60m | SSB | 59 | 59 | PJ | ||
12:40 | M0XRS | 60m | SSB | 59 | 59 | Chris | ||
12:41 | M0JLA/P | 60m | SSB | 59 | 59 | Rod | SOTA | G/WB-002 |
12:41 | EI7GEB | 60m | SSB | 59 | 59 | David | ||
12:42 | G3YZY | 60m | SSB | 59 | 59 | Howard | ||
12:43 | G0FVH | 60m | SSB | 58 | 44 | DAVID. | ||
12:46 | SP9MA/P | 20m | SSB | 59 | 59 | Jarek | SOTA | SP/BZ-012 |
12:48 | SP3W/P | 40m | SSB | 59 | 59 | Sebastian | COTA | SP-00037 |
12:54 | SP9BIJ/P | 40m | SSB | 57 | 55 | Marco | SOTA | SP/BZ-065 |
12:56 | SV2RUJ/P | 20m | SSB | 59 | 57 | Stavros | SOTA | SV/TL-066 |
13:02 | EA2IF/P | 30m | CW | 559 | 519 | Guru | SOTA | EA2/SS-057 |
13:11 | EA1FIC | 20m | SSB | 59 | 59 | Roberto | ||
13:12 | EA3HYJ | 20m | SSB | 59 | 55 | Agustín | ||
13:12 | N2BTD | 20m | SSB | 51 | 51 | BRIAN | ||
13:13 | EA4M | 20m | SSB | 59 | 57 | Ricardo | ||
13:13 | EA7JXZ | 20m | SSB | 59 | 57 | David | ||
13:14 | YU3FMS/P | 20m | SSB | 59 | 59 | Filip | POTA | YT-0001 |
13:17 | IK3RIY | 20m | SSB | 59 | 57 | Martino | ||
13:25 | MW3TMX/P | 40m | CW | 599 | 599 | Jordan | SOTA | GW/NW-036 |
13:31 | DL7BC/P | 40m | CW | 599 | 599 | Hartwig | SOTA | DM/BW-010 |
13:38 | OE5EEP/P | 20m | CW | 599 | 599 | Heinz | SOTA | OE/SB-458 |
13:39 | IW2OBX/P | 20m | CW | 559 | 559 | Roberto | SOTA | I/LO-252 |
14:02 | EA2ESE/P | 20m | SSB | 59 | 57 | Koldo | SOTA | EA2/BI-056 |
14:23 | RW3AG | 40m | SSB | 59 | 57 | Vlad | ||
14:28 | YI1WWA | 20m | SSB | 59 | 57 | Wisam | ||
14:32 | II4WRTC | 20m | SSB | 59 | 59 | WRTC | ||
14:32 | 9A/S57MS/P | 20m | SSB | 55 | 57 | Marko | SOTA | 9A/PH-038 |
14:57 | MI0TXM | 20m | CW | 519 | 559 | Andrew | SOTA | GI/MM-010 |
15:05 | KA2HTV | 20m | SSB | 59 | 57 | Dave | ||
15:10 | EA2GM/P | 20m | CW | 559 | 559 | Javier | SOTA | EA1/AT-208 |
15:30 | KC3PIP | 20m | SSB | 55 | 55 | DALE | POTA | K-4356 |
16:00 | G6NHW | 80m | SSB | 59 | 59 | PETE | ||
16:02 | ON4UP | 80m | SSB | 59 | 33 | Peter | ||
16:04 | M1DYU | 80m | SSB | 58 | 59 | Gary | ||
16:04 | 2E0ESY | 80m | SSB | 59 | 59 | Mike | ||
16:08 | 2E0FEH | 80m | SSB | 59 | 57 | Karl | ||
16:09 | G8ADD | 80m | SSB | 59 | 59 | Brian | ||
16:11 | 2E0BTR | 80m | SSB | 59 | 59 | Geoff | ||
16:13 | M0FXX | 80m | SSB | 59 | 59 | Robert | ||
16:14 | M0BQF | 80m | SSB | 59 | 59 | Mick | ||
16:16 | M7GMP | 80m | SSB | 59 | 59 | Karl |
Not much DX in the log but of note was my second contact with YI1WWA Wisam in Baghdad who’s pileup I happened across by chance and somehow managed to break straight through. KA2HTV was a big signal but with a 5 over 5 over 5 antenna at 176 feet that isn’t too much of a surprise! I also enjoyed a good group of contacts on 60m and 80m.
Next weekend our local panto starts a run for a week and I have volunteered as follow spot, so my radio activity will be taking a backseat for a while. Both my wife and daughter are in it this time round!
As the sun was setting the moon rose which was a magical end to the day, with the lake taking on a distinctive pink hue.
