GM/SS-016 & GM/SS-006: Back on the Horse
It had been a fair few weeks since my last SOTA activation, one that hadn’t ended particularly well. It had also been just a day short of a year since my very first ever SOTA activation. Whatever else it might have been, the important thing was that I had a Monday off work, no other engagements, and an absolutely fantastic looking weather forecast on my side.
The small problem I had however, was that my driving licence had recently expired, so until I could get a new one in the post from the DVLA, I was stuck with whatever I could activate from the train. Thankfully, the West Highland Line passes quite a few nice summits between Glasgow and Oban/Mallaig, so my choice was mainly based on what I could squeeze in with the timetables and rapidly decreasing daylight availability. I opted for the easiest possible option, and picked GM/SS-016, Beinn Narnain, with the option of adding GM/SS-006 Beinn Ime if time allowed.
These two hills had also been the first Munros I did as an adult (I’d done a couple at school etc.) back in 2012, and that time, I’d done the slightly foolish thing of taking the main path up the glen towards Beinn Ime, then on the return leg branching off towards Beinn Narnain, then dropping down the steep front face of Beinn Narnain back down towards Arrochar. This time, the plan was to ascend the steep scrambly bits on the way up to Beinn Narnain, then either drop back down to the bealach and home via the main path, or scoot out and back to Beinn Ime from there.
The train got me into Arrochar & Tarbet just before 10:00, and I then followed the path up the hill out of the station and round the shoulder of GM/SS-218 Cruach Tairbeirt, before dropping down into Arrochar and heading round the top of Loch Long to the start of the hill paths. The car parks at the head of the Loch had clearly taken a bit of a battering from the previous weekend’s storms, with the local council workers having to use a mini digger to clear mountains of flotsam and jetsam off the paths and roadways.
Once I got up onto the hills, the weather conditions were absolutely perfect. I’d expected a bit of a fresh one from a crisp sunny day in November, but the lack of wind meant that I was soon making my way up Beinn Narnain with just a t-shirt on top. With a bit of height gained, there were soon views through the pass at Tarbet to Loch Lomond, with a nicely lit GM/SS-011 Ben Lomond behind.
Another welcome bonus on the way up Beinn Narnain was the view down Loch Long to the Firth of Clyde, with GM/SS-246 Ailsa Craig just about visible on the horizon, and the various other islands, including the dramatic skyline of Arran making an appearance too.
The climb up to Beinn Narnain is a pretty relentless one, it seems to stay pretty steep most of the way, and probably reaches its hardest point at the rocky pinnacles which I think were named as the Spearhead on the map, with a wee bit of light scrambling required up a rocky gully. It did look like there were alternative options available to the right hand side, but with the rock being nice and dry, the route straight up the middle seemed appealing.
After the last wee bit of climbing, the summit itself is a fairly spacious plateau, and I set up my Slim G on the 4m fibreglass pole on a small rise just to the east of the summit marker. For a Monday, the hill was reasonably busy, but there was plenty of room for everyone. I even got to practice a wee bit of my ropey Spanish while taking a couple of summit photos for some overseas visitors.
I managed to rack up 11 QSOs on 2 metres in about a 25 minute period. It was one of those days where I’d have gladly hung around and chatted all afternoon, but I started weighing up the possibility of being able to get another activation over on Beinn Ime and still making it down in time for a sensible train home. One highlight was getting to hear that Archie @GM4KNU had been given the all-clear to get back out on the hills after some injury troubles, but I also owe Peter @GM7STP an apology for getting his name wrong, sorry! :flushed_face:
You can maybe see in this photo why I didn’t want to leave. You can probably also see the remnants of my last SOTA activation visible on the bridge of my nose!
Anyway, I started to pick my way through the rocks back down to the Bealach a’ Mhaim, and very quickly started back into hauling myself straight back uphill towards Beinn Ime. As I was approaching the summit, I could hear @MM7DGC making his first ever simplex QSO with the familiar voice of @MM9PDY from Blairskaith Muir on the edge of Glasgow - they would be my first two contacts on what would need to be a very swift activation on GM/SS-006 Beinn Ime.
While I normally like to have a wee short chat on my activations, this time it was all business, managing to get 10 QSOs in about 11 minutes before deciding that was enough. On this summit, I didn’t even bother sticking the Slim G in the air, opting to give my recently-replaced RH-770 its first proper hill outing, and it performed admirably on the FT-270.
Thankfully, the minimal rig meant minimal packup time, and I was trying to get back down the hill as rapidly as possible to make sure I didn’t miss my intended train - I would’ve had about two and a half hours to wait for the next one. A special mention needs to go to @MM9CRT who saw my spot and cycled up his local hill to try and chase me - I was able to make a QSO, but only by the time I was about 100 vertical metres below the activation zone height.
As I was descending, the light was just getting better and better, with the sun lowering in the sky and casting long shadows to greater emphasise the shape of the land. A particular favourite view was the one across Loch Lomond towards Loch Arklet and Loch Katrine with GM/SS-023 Ben Ledi behind.
Despite the longer-than-I-remembered drop down the main path past the Narnain Boulders down towards Arrochar, the brevity on Beinn Ime paid off, and I was able to make it back to Arrochar & Tarbet station with about ten minutes to spare, although I’m not sure if I saved or cost myself time by opting to take the longer but flatter route round the road from the village to the station rather than the Cowal Way path.
Oh, and I didn’t end up in hospital this time, so that was a bonus!
Beinn Narnain Log
Beinn Ime Log
Strava activity
Splendid photos of a cracking day out.
Sorry to have missed you for s2s from King’s Seat GM/SS-221, although a beautiful day up there too it did get very cold.
Train was a good travel option for me as well since it was too frosty for the bike, also the walk up the hill starts from the end of the Dunkeld station platform !
Andy MM7MOX
Glorious photos, what a lovely day. So nice to be able to do these (or any!) hills from the train station.
:eyes:
Doing them using the West Highland Railway is a real treat. Lots more to knock off before the train reaches Fort William!
Sublime photos. Mo and I did these in the heat of summer. Almost did The Cobbler on the way back, but the promise of a cold beer won that argument. IIRC, I worked a Welsh summit from Ben Narnain on 2m FM that day. :blush:
Jolly photos, nice Autumn colours. I’ve done Ime and The Cobbler singularly… I’m almost spent by the time I get col and the paths for all 3 meet so I’m impressed when anyone does 2 or more in one go. My dislike of plunging to my death from a scrambling slip means I’ll do Narnain from the back. And come back that way too!
It never ends… you get to the woods and then the zig zags start. ISTR 26 of corners to navigate. Shouldn’t be allowed.
:joy: I’m sorry there is no need to apologise for that ! :rofl:
Ross it was great to Chase you on both Beinn Narnain and Beinn Ime. :partying_face:
I was up Beinn Ime in May this year, but trekked in from Glen Croe from the car park on the A83 up to Bealach a Mhaim and the on up to Beinn Ime.
I thought about doing Beinn Narnain too, but not for long and headed straight back down to the car, leaving Beinn Narnain activation for another day.
So thanks for the Complete for Beinn Ime and setting me up for a Complete for Beinn Narnain. :smiling_face_with_sunglasses:
73 Peter
Aye, I drew the line on SOTL.as and it looked like we probably wouldn’t have made line of sight anyway, it looked like Ben Chonzie & Auchnafree Hill would’ve provided a pretty significant obstacle for VHF.
Aye, it’s always good when you get one straight out of the station. I’ll need to go back and have a go at activating GM/SS-218 Cruach Tairbeirt with that same idea.
Yeah, the train’s great, there are plenty of brilliant hills off the West Highland Line, it’s how I got most of my hillwalking done when I was a student. The main thing I miss these days is being able to sip on a room temperature can of overpriced Tennents from the trolley on the way back home! We did get a really nice sunset that evening, and again it was great being able to just sit and look at it rather than sitting in the usual bumper-to-bumper traffic down the side of Loch Lomond.
I reckon two’s just fine, that was still about 21km on the ground (albeit with a couple of extras getting to and from the railway station. The Cobbler’s a hill I’ve never actually been up before, I’m always slightly put off by the idea of the summit being full of flip-flop-wearing muppets with bluetooth speakers etc., although I’m sure the reality’s nowhere near as bad as I imagine.
Funnily, I don’t remember these at all from when I first climbed these hills in 2012 - my dodgy old HTC phone’s GPS track shows that I skipped all those switchbacks altogether and took a more direct route up the side of a burn. That’s not to say that they weren’t there, possibly just as likely that my nav wasn’t quite as sharp back then.
Oh there absolutely is, you were my first ever SOTA chase so you’d think I’d do a better job of committing that to memory!
Aye, I still quite fancy giving it a bash from that side. Beinn Luibhean (GM/SS-025) next door is very much on my to-do list as well, another classic example of a hill under Munro height that’s a lot more fun looking than a lot of the lumps that do make the list!
Aye, I personally quite enjoyed the wee scramble up the direct route to Narnain, it’s not really a plunge to your death kind of one, more of a fall and really awkwardly hurt yourself kind of job, which might be worse depending on your outlook on these kind of things. Coming down towards the Bealach a’ Mhaim and back down the main path is definitely the more sensible descent route though.
