G/WB-??? What does RNBGate do?
arno, 73
found answer in FAQ in KU6J´s homepage!!!
arno, 73
In reply to OE9AMJ:
Yes, it spots it just as alerted with the ‘???’. The expectation is that a chaser will give an updated spot with the correct ref.
Barry N1EU
In reply to OE9AMJ:
Arno
I listed the summit as G/WB-?? for 2 reasons.
I didn’t know what the access on the minor roads would be like because of the recent snow.
Because of the above, I didn’t know the order I’d be activating or how many summits I’d get round. I ended up doing only 2 but had 4 possibilities in the bag!
To avoid confusion I left the summit info out and relied on chasers picking it up on line.
It seemed to work fine!
Pete
In reply to G4ISJ:
hallo Pete,
the same with me.
Sometimes the decision what summit is possible u desire when u checked the snow situation “stop or go”, time, …
I wanted to check the possibility of using RNBGate with “???â€Â´s
I use RNB Gate:
Limited time on back skiing tour
Not heard on 20m, contest on 40. I use qrp.
No SMS-spot possible, because there is no phone net.
It is better in summertime, because u can send s2s into a pileup and get attention. But there are not so many activities in winter.
73, de arno
