On the way back from dropping Mrs M0VAZ at Blackpool for a 10pin bowling weekend, I decided to activate G/SP-017 - Billinge Hill
Parking in Beacon Road at the far end and then a 15min walk to the summit.
Weather was dry with some winter sun and damp ground.
Got setup over by the trig point, spotted and then cracked on with 2m.
A total of 28 contacts in around 35mins - thanks chasers.
From the summit
Hancock gave the only valid way to describe if it is raining over amateur radio is using the time worn phrase “It is, ah, raining not here also!” . But in your case it was.
Its not the best looking summit, but it is an easy walk for 1 point. Easy to get to with as well.
I think this is the 2nd easiest summit I have, 2nd to the Great Orme.
