G - Association Update 2023
I have been looking through all the G SOTA summit data on the Hills-Database make sure that all data of G SOTA summits are up to date and the SOTA Database should be updated with this as part of the September updates and the updated ARM should be uploaded onto SOTA Website later this month.
The main change is the relocation of the summit of Seager Hill G/WB-022, but there are other updates as well. I have updated the G/SE regional notes to remove the mention of Cheriton Hill G/SE-015 as this is no longer a SOTA summit. Below of a list of all other G SOTA summit updates.
Bredon Hill G/CE-003 - Prominence changed
Kit Hill G/DC-003 - Height (meters only) and prominence changed
Carnmenellis G/DC-006 - Prominence changed
Hensbarrow Downs G/DC-008 - Prominence changed
Scafell Pike G/LD-001 - Prominence changed
Great Gable G/LD-005 - Prominence changed
High Stile G/LD-012 - Height changed
Stony Cove Pike G/LD-018 - Height and prominence changed
Harter Fell (Eskdale) - G/LD-028 - Height and prominence changed
Illgill Head G/LD-029 - Prominence changed
Low Fell G/LD-042 - Height and prominence changed
Hallin Fell G/LD-043 - Prominence changed
High Rigg G/LD-044 - Height and prominence changed
Holme Fell G/LD-051 - Height and prominence changed
Whitbarrow - Lord’s Seat G/LD-056 - Prominence changed
Swinside G/LD-057 - Height and prominence changed
Muncaster Fell G/LD-059 - Prominence changed
Whernside G/NP-004 - Grid reference, heigh and prominence changed
Ingleborough G/NP-006 - Height and prominence changed
Great Coum G/NP-011 - Height and prominence changed
Great Knoutberry Hill G/NP-015 - Prominence changed
Calf Top G/NP-022 - Prominence changed
Hoove G/NP-024 - Prominence changed
Peel Fell G/SB-004 - Prominence changed
Sighty Crag G/SB-005 - Prominence changed
Tosson Hill G/SB-007 - Height and prominence changed
Long Crag G/SB-008 - Height and prominence changed
Ros Castle G/SB-009 - Height and prominence changed
Beacon Batch G/SC-003 - Prominence changed
Win Green G/SC-008 - Prominence changed
Lewesdon Hill G/SC-009 - Height and prominence changed
Hardown Hill G/SC-011 - Prominence changed
Nine Barrow Down G/SC-013 - Height (meters only) and prominence changed
Brighstone Down G/SE-012 - Height and prominence changed
Cliffe Hill G/SE-014 - No changes down, but I noticed that prominence for this on Hills-Database is 149.8m. RHB have left this hill as a Marilyn for the time-being due to potential marginal error at col. To save confusion, I have left the prominence as 150m on the ARM. It’s possible that in the future that this hill could be found to be no longer a Marilyn and if that is to be the case, it will need to be removed from the SOTA programme.
Ward’s Stone G/SP-003 - Height and prominence changed
Shining Tor G/SP-004 - Prominence changed
Fair Snape Fell G/SP-007 - Height and prominence changed
Hail Storm Hill G/SP-009 - Prominence changed
Winter Hill G/SP-010 - Height and prominence changed
Longridge Fell - Spire Hill G/SP-014 - Height and prominence changed
Billinge Hill G/SP-017 - Height and prominence changed
Guisborough Moor G/TW-003 - Height and prominence changed
Long Mynd - Pole Bank G/WB-005 - Prominence changed
Caer Caradoc Hill G/WB-006 - Prominence changed
The Wrekin G/WB-010 - Prominence changed
Garway Hill G/WB-013 - Prominence changed
Callow Hill G/WB-015 - Height and prominence changed
Wapley Hill G/WB-016 - Height and prominence changed
Hegdon Hill G/WB-023 - Prominence changed
From the above, I can see that since my last update back in February 2021, the prominences for a lot of G SOTA summits have changes and heights for quite a few G SOTA summits have changed also.
Jimmy M0HGY
G - Association Manager
