Allegra to the round
I need your swarm knowledge.
A few months ago I stumbled across an OM who operates FT8 on SOTA with a DigiLink and a GPD Micro PC.
Since the GPD was not available, I switched to an ASUS Chromebook CM3, which has ChromeOS as its operating system.
To get WSJT-X to fly I had to load a Linux emulator - this hurdle has been taken.
Where I keep failing now is the setting for the sound card because my tablet only has a USB3 port to which I connect the DigiLink which is the sound card for my KX3. (The manufacturer of the DigiLink uses it on his KX2 so it must work). But the selection is so big from samplerate over vdownmix and plughw:CARD=SoundCard,DEV=0 to alsa_input.hw_0_0. On the radio card, since there is no CAT, I have the interface selection from /dev/ttyS3 down to /dev/ttyS0 and USB. I have tried several combinations but I always get a Hamlib error.
Who knows what I am doing wrong again as a DAU?
